Read JSON file into variables?  [Solved]
doh
Post by doh »
I'm trying to use pynetgear_enhanced to retrieve a list of connected devices from my NetGear Router and then use this to update presence status in Domoticz.
I've got a cron job running every minute that retrieves the list of connected devices and writes it to a JSON text file.
How can I read this JSON text file into dzVents so I can then process the contents?
Here's a sample extract of the file:
    "name": "SonyBravia",
    "ip": "192.168.1.176",
    "mac": "04:5D:4B:DA:52:B1",
    "type": "wired",
    "signal": 100,
    "link_rate": null,
    "allow_or_block": "Allow",
    "device_type": null,
    "device_model": null,
    "ssid": null,
    "conn_ap_mac": null
    "name": "XBOXONE",
    "ip": "192.168.1.120",
    "mac": "94:9A:A9:2E:33:9F",
    "type": "wired",
    "signal": 100,
    "link_rate": null,
    "ssid": null,
    "conn_ap_mac": null
Re: Read JSON file into variables?  [Solved]
doh wrote: Tuesday 28 July 2020 17:07 How can I read this JSON text file into dzVents so I can then process the contents?
Use below bash script example
#!/bin/bash
# signal dzVents about a JSON in an OS file
# vars to be changed
JSONFile='/opt/domoticz/myJSONFile' # change to full qualified filename
domoticzPort=8084                   # change to your domoticz port number
domoticzIP=127.0.0.1                # change to domoticz IP (keep 127.0.0.1 if local)
# Keep this the same as the trigger of the dzVents script
customEvent=JSONFileReady
# signal dzVents
curl "http://$domoticzIP:$domoticzPort/json.htm?type=command&param=customevent&event=$customEvent&data=$JSONFile"
and this dzVents
return
    on =
        customEvents =
            'JSONFileReady',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Read JSON file',
    execute = function(dz, item)
        local function readFile(f)
            local file = io.open (f, 'r') -- open file in read mode
            local data =  file:read('*a')  -- read all
            file:close()
            return data
        --main
        local convertedJSON = dz.utils.fromJSON(readFile(item.data))
        dz.utils.dumpTable(convertedJSON)
doh
Post by doh »
Thanks - I've moved to using a customEvent now, so the routine only runs when the Cron job completes.
