How to make Domoticz read I2C data directly from the GPIO?
Posted: Tuesday 28 July 2020 15:18
by pgielen
I am looking for a way to read I2C data in Domoticz from the Raspberry Pi 4B that Domoticz is running on. I have recently installed a X728 power management board on this RPi, in order to make my Domoticz system less vulnerable to power failure.
The X728 uses two GPIO pins for a I2C interface to send the voltage and battery levels to the RPi and I want to read out these values directly into Domoticz, but can't find out how. I tried to use the I2C sensors hardware type in Domoticz, but this seems to be meant for other hardware.
Is there another way? There should be. The X728 board does come with a Python example for sending voltage and battery levels to the console, but I could not import that script (which runs fine when executed from the CLI) into the Domoticz script system because I immediately get an error in line 3, where it says: import smbus. This lib is installed on my system. Python finds it, but Domoticz doesn't.
And then there is the question about how to get the data into Domoticz variables. The Wiki is not clear on how to do this. Running the script outside of Domoticz and then sending a http request with the data over the internet could work, but really doesn't sound like an elegant solution for two devices that are physically connected to eachother. So what else could I try? I am not asking for a specific solution in Python, just some easy way to get the job done.
BTW the X728 example script is here:
#!/usr/bin/env python
import struct
import smbus
import sys
import time
def readVoltage(bus):
     address = 0x36
     read = bus.read_word_data(address, 2)
     swapped = struct.unpack("<H", struct.pack(">H", read))[0]
     voltage = swapped * 1.25 /1000/16
     return voltage
def readCapacity(bus):
     address = 0x36
     read = bus.read_word_data(address, 4)
     capacity = swapped/256
     return capacity
bus = smbus.SMBus(1) # 0 = /dev/i2c-0 (port I2C0), 1 = /dev/i2c-1 (port I2C1)
while True:
 print "******************"
 print "Voltage:%5.2fV" % readVoltage(bus)
 print "Battery:%5i%%" % readCapacity(bus)
 if readCapacity(bus) == 100:
         print "Battery FULL"
 if readCapacity(bus) < 20:
         print "Battery LOW"
 time.sleep(2)
Re: How to make Domoticz read I2C data directly from the GPIO?
Posted: Tuesday 28 July 2020 17:01
by waaren
pgielen wrote: Tuesday 28 July 2020 15:18 And then there is the question about how to get the data into Domoticz variables. Running the script outside of Domoticz and then sending a http request with the data over the internet could work, but really doesn't sound like an elegant solution
This is a perfectly good solution. The domoticz API is designed for this and your http request will not leave the system. If you enter 127.0.0.1 or the IP address the system received from your router, your network interface will recognize that. No intranet or internet will be used.
Posted: Wednesday 29 July 2020 23:28
by pgielen
Okay then, this works as an external Python script, but still not from within the Domoticz script system:
import struct
import smbus
import sys
import time
import requests
     address = 0x36
     return voltage
     address = 0x36
     if (capacity > 100): # Added because the capacity sometimes reaches > 100
          capacity = 100
     return capacity
bus = smbus.SMBus(1) # (port I2C1)
voltage = "%.2f" % readVoltage(bus)
battery = "%i" % str(readCapacity(bus))
url = "http://127.0.0.1:8088/json.htm?type=command&param=udevice&idx=561&nvalue=0&svalue=" + voltage
r = requests.get(url)
#print(r) # for debugging: result should  be 200 = OK
url = "http://127.0.0.1:8088/json.htm?type=command&param=udevice&idx=562&nvalue=0&svalue=" + battery
#print(r)
(idx 561 is a virtual device of the type Voltage, idx 562 is a virtual device of the type Percentage)
I have it working when triggered as an external script through crontab, but if i try to run this code from within the Domoticz script system, I still get:
2020-07-29 12:04:40.152 Error: EventSystem: ModuleNotFoundError: No module named 'smbus'
Could this error be related to a PATH variable or something like that, or is the Python version built in Domoticz just a bit more limited than the full version?
