domoticz.utils.osExecute problem
Posted: Monday 27 July 2020 15:02
by Hansh
Hi there,
I am making a script. The intention is that when the switch goes off, it first stops another raspberry in the network. and then turn off another switch about 30 sec later.
In itself a fairly simple script.
The problem lies in controlling the other raspberry. the raspberry where domoticz runs on can control the other raspberry by ssh, to do that I created an ssh keypair.
the command
ssh [email protected] 'sudo poweroff'
works fine and the remote raspberry is actually stopped
When this command is processed in a dzevents script it will no longer work. Does anyone have any idea to get this working.
the script i wrote:
		devices = {
			'3d printen'
	    if device.state== 'Off' then
	        domoticz.utils.osExecute("ssh [email protected] 'sudo poweroff'")
		    domoticz.log("shutting down in 30 sec")
	        domoticz.devices(139).switchOff().afterSec(30)
Re: domoticz.utils.osExecute problem
Posted: Monday 27 July 2020 17:00
by waaren
Hansh wrote: Monday 27 July 2020 15:02 The problem lies in controlling the other raspberry. the raspberry where domoticz runs on can control the other raspberry by ssh, to do that I created an ssh keypair.
Is domoticz executed by user pi? If not did you test with the same user?
Posted: Monday 27 July 2020 23:06
by Hansh
Thanks for the reply
A quick scan shows that domoticz was indeed started by user root.
I'm going to work on this. When I know a bit more I will let you know.
I had not yet thought of this possibility.
mvg Hans
Re: domoticz.utils.osExecute problem  [Solved]
Posted: Wednesday 29 July 2020 15:22
by Hansh
@ waaren
This was the problem. After I created an ssh keypair for the root, the script worked perfectly.
Thanks again for the help
gr Hans
