controlling multiple devices at once
Posted: Sunday 26 July 2020 13:25
by markjgabb
hey all im interested in controlling multiple devices at once... i tried the below code, but only the first device is controlled
any tips on why one is working but the other is not?
i know its something wrong with the local HallLight.... but im not sure why it doesnt apply correctly
		devices = {['Loungeroom motion sensor'] =  {'at nighttime'}}
	execute = function(dz, item, device)
	    local moodLight = dz.devices('Mood Light')
	    local HallLight = dz.devices(10,11)
        local delay = 120
	--	dz.log('Device ' .. device.name .. ' was changed', dz.LOG_INFO)
		if item.state == 'On' then
		    if item.active then
            if dz.time.matchesRule('between 23:00 and sunrise') then
                moodLight.cancelQueuedCommands()
                moodLight.dimTo(15)
                moodLight.switchOff().afterSec(delay)
                HallLight.cancelQueuedCommands()
                HallLight.dimTo(15)
                HallLight.switchOff().afterSec(delay)
                moodLight.dimTo(100)
                HallLight.dimTo(100)
Re: controlling multiple devices at once
Posted: Sunday 26 July 2020 14:25
by hestia
10,11 ?!?
maybe 10 or 11, not both...
Posted: Sunday 26 July 2020 14:38
by waaren
markjgabb wrote: Sunday 26 July 2020 13:25 I know its something wrong with the local HallLight.... but im not sure why it doesnt apply correctly
You cannot assign two devices to one variable using above syntax.
Can you try this ?
return
    on =
        devices =
                'at nighttime',
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when al OK
        marker = 'Loungeroom motion',
    execute = function(dz, item)
        if item.active then
             local allLights =   {
                                dz.devices('Mood Light'),
                                dz.devices(10),
                                dz.devices(11),
            local delay = 120
            dimLevel = dz.time.matchesRule('between 23:00 and sunrise') and 15 or 100
            for _, dv in ipairs(allLights) do
                dv.cancelQueuedCommands()
                dv.dimTo(dimLevel)
                dv.dimTo(0).afterSec(delay)
Posted: Tuesday 28 July 2020 12:37
by markjgabb
hey that works... makes script alot smaller too thank you
