Z-Wave queue full? (Domoticz stuck)
Posted: Sunday 26 July 2020 12:54
Hi guys,
I have installed some sunscreens and control these with the TKB home TZ75 shutter relais.
Weather info, a PIR (Lux) and manual input control the screens. If I have the (Blockly) script turned on and the screens are triggered, the Zwave part of Domotics gets stuck (I say Zwave part, because the Zigate/Zigbee part of the switches keep working normally). Commands to other switches take ages to be executed. In the end, most of them are executed. If you switch a light on and of a couple of times, the queued jobs are executed as a batch (flickering light as a result).
If the script that controls the screens is turned off, after half an hour Domotics turns back to normal operation.
I've been going through the debug log, but I don't know what to look for. There are some error messages about dropping commands and data not being delivered to the Zwave stack. I also don't know how to see if a command is sent, received and executed, or queued. And if/when it's queued, see if it is actually executed later.
I would be helped if someone could tell me what the nomenclature of the messages are, to look for with these symptoms.
Best regards,
Tonka
Best regards,
Tonka
