Swiper
Scotty
Swiper
Post by Scotty »
Hey hey.
Is it possible to disable the swiper but still use multiple screens?
I'd like to be able to use the buttons I have set up to go to different screens but not use the physical gesture of swiping on the screen as I'm too clumsy and usually end up swiping when trying to press a switch.
The following disables the use of screens altogether instead of just disabling the swipe gesture.
config['enable_swiper'] = 0;
Lokonli
Re: Swiper
Post by Lokonli »
Scotty wrote: Saturday 25 July 2020 17:46 Hey hey.
Currently that's not possible, but it's a small enhancement.
I'll add it to the list.
FreakNL
Re: Swiper
Post by FreakNL »
Yes, it's possible. It's even in the docs..
https://dashticz.readthedocs.io/en/mast ... cellaneous
HansieNL
Re: Swiper
Post by HansieNL »
FreakNL wrote: Saturday 15 August 2020 18:57 Yes, it's possible. It's even in the docs..
With the css trick in the docs you don’t disable swiping, but only hide the swiping dots.
Blah blah blah
FreakNL
Re: Swiper
Post by FreakNL »
Ah, you are correct, I thought he just wanted to disable the buttons :)
Lokonli
Re: Swiper
Post by Lokonli »
This has been implemented in latest beta.
To disable swipe on touch move add the following to CONFIG.js:
config['swiper_touch_move'] = 0;
