Auto slide screen improvements
Posted: Monday 20 July 2020 8:26
How about to improve the aut slide screen?
Iam using a 12in touch screen, the settings are for 10screens, with auto slide for every 120 sec.
My problem is: at the moment then I use a screen, for example switch on-off something, or looking a cam in frame, after the 120 sec passes, the screen jumps to next one. So I need to press the previous screen to finish my settings.
How about to improve the auto-slide function to reset the timer to next screen with parameters, like:
- if button is pressed on current screen the timer should be restarted, to be able to see the changes, without need to press again the prev screen!
- with variable
- with option, if a change will accur in the particular screen, then jump there? ex: switch receive change.
- if touch screen senses a touch/click
Thanks for considering the idea.
- with variable
