What's the exact use of an event
Posted: Sunday 19 July 2020 13:51
by roblom
I have a Fibaro smoke sensor. This gives a whopping 10 devices. Most of them have a switch and an alarm device. For example there is a smoke alarm with subtype switch but also a smoke alarm with subtype alarm.
What's the exact use of these? I've googled but cannot find a clear answer so maybe someone here can explain it to me.
Verstuurd vanaf mijn ELE-L29 met Tapatalk
Re: What's the exact use of an event
Posted: Friday 25 September 2020 8:54
by nschoot
I am curious about this as well. I read before that device ending with 29 should be used. However, last night (always at night), my Domoticz system started rining the alarm because there was a smoke sensor ON.
And indeed, there was a smoke sensor in the system with device 29 set to ON. For just a moment. However, the physical smoke sensor itself did not trigger/sounded the alarm.
So, my guess is that the smoke sensor uses 29 as input, but only combined with other data.
I am considering to start using device 32 instead. This is a switch called "Alarm Level". But it would be great to get some sort of explanation of these devices.
Posted: Saturday 21 November 2020 12:44
by roblom
Exact same questions here and also could not find an answer.
Posted: Tuesday 24 November 2020 17:57
by meal
Here are some information I grabbed from websites
ALARM TYPE ENTITY
• Version 2 alarm_type:
o 0: General purpose
o 1: Smoke sensor
o 2: Carbon Monoxide (CO) sensor
o 3: Carbon Dioxide (CO2) sensor
o 4: Heat sensor
o 5: Water leak (flood) sensor
o 6: Access control
o 7: Burglar
o 8: Power management
o 9: System
o 10: Emergency
o 11: Clock
o 12: Appliance
o 13: Home Health
ALARM LEVEL ENTITY
The meaning of the alarm_level entity depends on the nature of the alarm sensor.
• 0: No event
Smoke, CO, and CO2
• 1: Detection - will include a Node Location Report
• 2: Detection (unknown location)
• 254: Unknown event
Heat
• 1: Overheat detected - will include a Node Location Report
• 2: Overheat detected (unknown location)
• 3: Rapid temperature rise - will include a Node Location Report
• 4: Rapid temperature rise (unknown location)
• 5: Underheat detection - will include a Node Location Report
• 6: Underheat detection (unknown location)
Water leak
• 1: Water leak detected - will include a Node Location Report
• 2: Water leak detected (unknown location)
• 3: Water level dropped - will include a Node Location Report
• 4: Water level dropped (unknown location)
Access control
• 1: Manual lock
• 2: Manual unlock
• 3: RF lock
• 4: RF unlock
• 5: Keypad lock - will include the User Identifier of the User Code Report
• 6: Keypad unlock - will include the User Identifier of the User Code Report
Burglar
• 1: Intrusion - will include a Node Location Report
• 2: Intrusion (unknown location)
• 3: Tampering (case opened)
• 4: Tampering (invalid code)
• 5: Glass break - will include a Node Location Report
• 6: Glass break (invalid code)
Power Management
• 1: Power applied
• 2: AC disconnected
• 3: AC re-connected
• 4: Surge detection
• 5: Voltage drop or drift
System Alarm
• 1: System hardware failure
• 2: System software failure
Emergency Alarm
• 1: Contact Police
• 2: Contact Fire Service
• 3: Contact Medical Service
Alarm Clock
• 1: Wake up
ACCESS CONTROL ENTITY
• access_control: These may vary between brands
o 22: Open
o 23: Closed
o 254: Deep sleep
o 255: Case open
And a template for use in LUA.
if (devicechanged[myAlarm]) then
if (otherdevices_zwavealarms[MyAlarm] == 2) then
Hoping it helps
BR
