Support for MCOHome A8-9 Multi-sensor
Posted: Wednesday 15 July 2020 12:53
by Jofre
I would like to see better support for this sensor.
2020-07-13 10:49:10.804 OpenZWave: Value_Added: Node: 50 (0x32), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 1, Index: 0
2020-07-13 10:49:10.804 OpenZWave: Value_Added: Node: 50 (0x32), CommandClass: SENSOR MULTILEVEL, Label: Air Temperature, Instance: 1, Index: 1
2020-07-13 10:49:10.804 OpenZWave: Value_Added: Node: 50 (0x32), CommandClass: SENSOR MULTILEVEL, Label: General Purpose, Instance: 1, Index: 2
2020-07-13 10:49:10.804 OpenZWave: Value_Added: Node: 50 (0x32), CommandClass: SENSOR MULTILEVEL, Label: Illuminance, Instance: 1, Index: 3
2020-07-13 10:49:10.804 OpenZWave: Value_Added: Node: 50 (0x32), CommandClass: SENSOR MULTILEVEL, Label: Humidity, Instance: 1, Index: 5
2020-07-13 10:49:10.804 OpenZWave: Value_Added: Node: 50 (0x32), CommandClass: SENSOR MULTILEVEL, Label: Carbon Dioxide, Instance: 1, Index: 17
2020-07-13 10:49:10.805 OpenZWave: Value_Added: Node: 50 (0x32), CommandClass: SENSOR MULTILEVEL, Label: Loudness, Instance: 1, Index: 30
2020-07-13 10:49:10.805 OpenZWave: Value_Added: Node: 50 (0x32), CommandClass: SENSOR MULTILEVEL, Label: Particulate Matter 2.5, Instance: 1, Index: 35
2020-07-13 10:49:10.805 OpenZWave: Value_Added: Node: 50 (0x32), CommandClass: SENSOR MULTILEVEL, Label: Volatile Organic Compound, Instance: 1, Index: 39
2020-07-13 10:49:10.805 OpenZWave: Value_Added: Node: 50 (0x32), CommandClass: SENSOR MULTILEVEL, Label: Smoke Density, Instance: 1, Index: 55
2020-07-13 10:49:10.057 Status: OpenZWave: ManufacturerSpecificDB Ready
MCOHome A-9 devices.PNG (34.29 KiB) Viewed 2919 times
Re: Support for MCOHome A8-9 Multi-sensor
Posted: Saturday 05 September 2020 11:36
by appletreelane
Hi Jofre,
curious what you would like to see more. From your screenshot it looks like you have all sensors accessible in Domoticz correct?
Posted: Thursday 17 September 2020 21:50
by appletreelane
I bought the mcohome a8-9 myself and now understand your request. Two sensors (movement and VOC) indeed do not work.
I already tried to do some edits to the file a8-9.xml in de mcohome folder but was not successful.
Anybody who has already succesfully integrated this device in Domoticz with Z-wave (aeotec USB running 1.6)
Any tips where to start?
Posted: Saturday 13 March 2021 13:04
by AMDomoticz
In this topic a similar problem: viewtopic.php?f=24&t=35726&p=270798#p270798
One sensors (VOC) don't work/appear in the devices tab. Is there a pattern?
Posted: Wednesday 07 April 2021 16:46
by AMDomoticz
Asustor | Domoticz 2020.2 (b63341bc0)| Aeotec USB (running 1.6) | MCOHome A8-9
Issues:
- VOC sensor doesn't show up in Domoticz; but it is in OpenZwave Control Panel.
- VOC sensor displays its value in the CO2 device (range 0.000 - 64.000)
- PIR sensor 0 or 1 as floating value. Result error in log:
(2021-04-07 15:36:00.902 Error: OpenZWave: Value_Changed: Unhandled value type ZDTYPE_SWITCH_NORMAL (2). Node: 5 (0x05), CommandClass: SENSOR MULTILEVEL, Label: General Purpose, Instance: 1, Index: 2 (OpenZWave.cpp:3189))
Workaround:
dzVents (Version: 3.0.2)
- on change copy values CO2 sensor to Custom CO2 Sensor if value > 64.000
PHP
- every 5 minutes get VOC value from /ozwcp/poll.xml
- use json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue= to update te value of the Custom VOC Sensor
Create dummy with 2 Custom Sensors
Sensor Type : Custom Sensor
Label : ppb
Label : ppm
Create dzVents script airQualityCO2:
      devices = {
         'Air Quality'   -- default name from A8-9
      if device.co2 > 64 then
            domoticz.devices(110).update( 0, device.co2 )   -- 'Woonkamer-CO2'
Create PHP script taskZwave05.php in /volume1/cron/05min/
still testing
Add in crontab
*/5 * * * * 	/volume0/usr/builtin/bin/php /volume1/cron/05min/taskZwave05.php
Stop and start the cron.
Shoot! I have no workaround for the PIR; anybody?
Update 11-05-2021: PIR works in 2021.1; values 0.000 / 1.000
VOC still not visible.
Posted: Friday 18 June 2021 11:11
by pshadoko
Hi months later...
I have the same device and same problems
MCOHome A8-9
Domoticz Version: 2021.1 Build Hash: 8547c5b7e Compile Date: 2021-04-17 16:29:11 dzVents Version: 3.1.7 Python Version: 3.7.3 (default, Jan 22 2021, 20:04:44) [GCC 8.3.0]
Thanks for the solution you offer for the VOC integration.
I noticed that the sensor that is called "General Purpose" in fact reports the state of the PIR sensor. It changes to 1 when movement is detected and remains at 0 otherwise.
I had to play with the Z wave parameter configuration to get this status report.
In the parameters either we choose a reading when the value of a sensor is modified (Parameters from 1 to 9), or we choose a reading at regular intervals (parameter 10 to 18).
You can mix the options depending on the probe.
For example it seems that if I choose a regular interval for the CO2 probe I display zero values ​​when it does not fall exactly during a variation of the CO2 value. So at 99% I had a zero CO2 rate (Finally equal to 1 with the default offset)
So I chose to modify the values ​​like this:
2.CO2 Delta Level: 1 (Actual: 1)
13. CO2 Timer: 0 (Actual: 0)
For other sensors I preferred a reading at regular intervals (brightness, noise) because the noise, for example, constantly changes and it did not seem necessary to me to report all these values
All this to say that by adjusting the following parameters:
8. PIR Delta Level: Report Change
11. PIR Timer: (Real: 0)
I notice a change of state of the "general purpose" sensor from 0 to 1 when a movement is detected.
What about the switch that is created in the domoticz devices? I wonder if it is not a switch that is activated on detection of a significant level of smoke?
Here is some view from console and domoticz (is it the same for you?
Zwave devices console view
Domoticz devices
Domoticz devices
Have you more returns to do at this time?
Posted: Sunday 04 July 2021 12:35
by pshadoko
for the PIR sensor you can report the state of the general purpose type sensor (0/1 values corresponding to movement or not)
With a dummy type sensor and a script that updates its state according to the state of the general purpose sensor.
# Script_device_pir.lua
local motion_detector = '$Motion sensor'
local motion_detector_device = 'MOUVEMENT'
local debug = 'On'
-- Déclaration des fonctions
	if (devicechanged[motion_detector]) then
		detect = tonumber(otherdevices_svalues[motion_detector])
		-- print (''..detect..'')
		if ( detect == 1.0 )	then
			commandArray[motion_detector_device] = 'On'
			if (debug == 'On') then print ('# MOUVEMENT : Détecteur '..motion_detector_device..' mis à On') end
		if ( detect == 0.0 ) then
			commandArray[motion_detector_device] = 'Off'
			if (debug == 'On') then print ('# MOUVEMENT : Détecteur '..motion_detector_device..' mis à Off') end
		if (debug == 'On') then print ('# MOUVEMENT : Fin du script') end
Posted: Sunday 04 July 2021 12:43
by pshadoko
Dear AMDomoticz I'm realy interested in your taskZwave05.php script because I never success to create the update of ozwcp.poll.XXXXXX.xml by reading the ozwcp page. I think it's the only way to get VOC value.
I dont understand why ozwcp can well read all the values and domoticz not?
Posted: Monday 09 August 2021 20:16
by AMDomoticz
Sorry for the late response. Busy preparing retirement and had a long vacation...
The php I use:
<?php
# Bron: http://192.168.1.11:9980/ozwcp/poll.xml
  $versie = '1.06 dd 10-08-2021';
# Doel: Domotics V2021.1 database
# Via : json.htm?type=command&param=udevice&idx=107&nvalue=0&svalue=
header('Content-Type: application/json');
date_default_timezone_set("Europe/Amsterdam");
ini_set('max_execution_time', 90 );  // seconds
ini_set('memory_limit', '512M');
$url = 'http://192.168.1.11:9980/ozwcp/poll.xml';
$sensors = ['Schemerlampjes','Boiler','Hal','Woonkamer'];
$result = json_encode( ['error' => 'time out...'] );
$teller = 0;
$run = true;
while ($teller < 5) {
	$tel = 0;
	while ($run) {
		$resultStr = file_get_contents($url);
		// splitsen in apparaten
		preg_match_all('#<node (.*?)</node>#si', $resultStr, $matches);
		if ( count($matches[0]) == count($sensors) ) {
			// voor ieder apparaat
			foreach($matches[0] as $match){
				if ( strpos($match, 'Woonkamer') && strpos($match, 'Volatile Organic Compound')) {
					preg_match('#label="Volatile Organic Compound" units="Ppm" readonly="true" polled="false">(.*?)<help>Volatile Organic Compound Sensor Value</help>#si', $resultStr, $voc);
					// ppm -> ppb
					$value = $voc[1] * 1000;
					if ($value < 0) {
						exit( json_encode( ['error' => 'value < 0, waarde is ' . $value] ) );
					} else {
						$url = "http://192.168.1.11:9980/json.htm?type=command&param=udevice&idx=107&nvalue=0&svalue=" . $value;
						$result = file_get_contents($url);
						$jsonArray = json_decode($result, true);
						if ($jsonArray['status'] == 'OK') {
							exit( $result );
			$tel = 100;
		$run = $tel++ < 5;
		// sleep before running the loop again
		usleep(500);
	sleep(10);
	$teller++;
echo $result;
The 4th sensor with the name 'Woonkamer' is, in my case, the MCOHome A8-9 Multi-sensor.
The file poll.xml is sometimes missing one or more devices. Then it loops and tries again.
Is the value found then it exits en writes the value to a Custom Sensor with the idx 107, name VOC, units ppb.
