Aqara water leak sensor
Posted: Monday 13 July 2020 13:45
I've used a couple of temperature sensors and a water leak / flood sensor from Xiaomi (Aqara) with their gateway for quite a while.
After purchasing a ZiGate I have dumped the Xiaomi gateway and added all sensors successfully to the ZiGate and back in Domoticz.
After adding the water leak sensor I decided to test it. When I drop it in water nothing happens in Domoticz. It's standard added as an On/Off switch by ZiGate. I already tried to change it to motion sensor but without luck. Can anyone tell me how I can configure this water leak sensor right so I can set up notifications when there is a real water leak?
Many thanks in advance!
