CCT LED on two MOSFETS
Posted: Friday 10 July 2020 10:07
Hello guys!
I hope i will not duplicate the topic... i already scherach on forum but i can't find something similar.
I've already built a MOSFET based one LED stripe dimmer project. I used the script in Domoticz and everything works perfect.
Now i want to build something for CCT LED stripe and i have to say... i don't know how to do this.
Main requirement is that dimmer change the light intensity proportionally. I mean 50% warm LED and 50% cold LED and so on.
is it any chance to customize this code or i need to create another one ?
Do i have to create another user variable for additional GPIO ?
Thank you in advance
best regards!
Tom
best regards!
Tom
DomDevice = 'LED1 ';
IP = '192.168.0.104';
PIN = "2";
FED ='1000'
if devicechanged[DomDevice] then
if(devicechanged[DomDevice]=='Off') then
print ("OFF dim = "..uservariables['dimmer']);
CalcValue = 0;
else if(devicechanged[DomDevice]=='On') then
DomValue = uservariables['dimmer'];
print ("ON dim = "..uservariables['dimmer']);
CalcValue = DomValue;
print("Other");
DomValue = otherdevices_svalues[DomDevice];
CalcValue = math.floor(DomValue / 100 * 1023);
commandArray['Variable:dimmer'] = tostring(CalcValue);
print ("dim Level = "..uservariables['dimmer']);
runcommand = "curl 'http://" .. IP .. "/control?cmd=PWM," ..PIN.. "," .. CalcValue ..",".. FED .. "'";
os.execute(runcommand);
print("PWM value= "..CalcValue);
