RFLink + Wi-Fi
garethiowc
RFLink + Wi-Fi
Post by garethiowc »
Hi All,
i have been using the rf link via USB for a couple of years but have decided to move it over to wi-fi using
https://www.nodo-shop.nl/nl/home/191-rf ... print.html
and
https://www.nodo-shop.nl/nl/home/189-nodemcu.html
after using an online translater I followed the setup guide - https://www.nodo-shop.nl/nl/index.php?c ... achment=35
So currently the nodemcu is connected to my wi-fi and I have configured the serial port as shown in the guide but domoticz doesn't grab any data from it
Screenshot 2020-07-04 at 09.32.21.png (126.74 KiB) Viewed 17022 times
Screenshot 2020-07-04 at 09.32.59.png (302.01 KiB) Viewed 17022 times
Screenshot 2020-07-04 at 09.14.05.png (74.96 KiB) Viewed 17022 times
garethiowc
Re: RFLink + Wi-Fi
Screenshot 2020-07-04 at 09.14.21.png (56.18 KiB) Viewed 17020 times
sorry, second post due to image upload limit.
any ideas where I might have gone wrong?
Petjepet
Re: RFLink + Wi-Fi
Post by Petjepet »
I run into the same issue where it has been working before.
There are no devices detected.
2020-08-09 11:44:56.926 Status: RFLink: trying to connect to 192.168.1.74:9999
2020-08-09 11:44:56.936 Status: RFLink: connected to: 192.168.1.74:9999
2020-08-09 11:44:56.926 Error: ASyncTCP: connect called while socket is still open. !!!
2020-08-09 11:45:36.931 Error: RFLink: Nothing received for more than 30 seconds, restarting...
2020-08-09 11:45:56.933 Status: RFLink: trying to connect to 192.168.1.74:9999
2020-08-09 11:45:56.934 Error: ASyncTCP: connect called while socket is still open. !!!
2020-08-09 11:45:58.153 Status: RFLink: connected to: 192.168.1.74:9999
2020-08-09 11:46:36.938 Error: RFLink: Nothing received for more than 30 seconds, restarting...
2020-08-09 11:46:56.940 Status: RFLink: trying to connect to 192.168.1.74:9999
2020-08-09 11:46:56.940 Error: ASyncTCP: connect called while socket is still open. !!!
2020-08-09 11:47:04.304 Status: RFLink: connected to: 192.168.1.74:9999
2020-08-09 11:47:36.944 Error: RFLink: Nothing received for more than 30 seconds, restarting...
2020-08-09 11:47:56.946 Status: RFLink: trying to connect to 192.168.1.74:9999
2020-08-09 11:47:56.957 Status: RFLink: connected to: 192.168.1.74:9999
2020-08-09 11:47:56.946 Error: ASyncTCP: connect called while socket is still open. !!!
2020-08-09 11:48:36.950 Error: RFLink: Nothing received for more than 30 seconds, restarting...
I can configure my NodeMCU (ESP) with no problem directly by it's IP address, so it is connected in my network (also visible in router).
EDIT: now I see the NodeMCU won't connect to Domoticz anymore. The Log says:
2020-08-09 12:27:14.780 Status: RFLink: connected to: 192.168.1.74:9999
2020-08-09 12:27:14.780 Status: RFLink: disconnected
2020-08-09 12:27:14.780 Error: RFLink: Bad address
Still able to connect it directly by IP address.
Any ideas?
Gr,
Ron
Gr,
Ron
BertB
Re: RFLink + Wi-Fi
Post by BertB »
I have the same problem.
Is there any progress?
Set 1= RPI 3B, latest Beta, RFLink USB, RFLINK WIFI, Zwave
Set 2= RPI 2B, Latest Beta, OTGW (USB), SBFSpot (Bluetooth)
erem
Domoticz version: 2021.1
Re: RFLink + Wi-Fi
Post by erem »
The ESPeasy version you are using is ancient.
A lot of progress has been made on wifi connectivity since version 147
i suggest you try one of the more recent versions from here https://github.com/letscontrolit/ESPEasy/releases
Regards,
Rob
BertB
Re: RFLink + Wi-Fi
Post by BertB »
Hi Rob,
That is not quite true. I run the latest Beta of ESPEasy
erem
Re: RFLink + Wi-Fi
Post by erem »
Bert,
according to the ESPEasy developers much improvements have been made in wifi stability.
you can setup a device in espeasy "generic system info" which can show RSSI, web activity etc.
that may help to determine the cause of the connection loss
if you make a sensor in domoticz that will keep the history for you
https://www.letscontrolit.com/wiki/inde ... le=SysInfo
if it is not a connection loss problem on the esp side, you can monitor the incoming rx/tx using the serial monitor on the esp, but you probably know that already :D
Regards,
Rob
BertB
Re: RFLink + Wi-Fi
Post by BertB »
I do indeed. Problem is, the error occurs only once in a couple of days.
erem
Re: RFLink + Wi-Fi
Post by erem »
maybe this will help.
this is a set of rules that will reboot the esp when a loss of connectivity occurs (that can be detected by the esp)
  // Rules for ESPEasy
on System#Boot do
    Let,1,0		// set uservariable
EndOn
on Wifi#Disconnected do	// if no wifi, wait 3 minutes
  if [VAR#1]=0
    timerSet,1,180
    Let,1,1		// set user variable 1 to 1
  endif
endon
on Wifi#Connected do	// if wifi returns, cancel reboot
  timerSet,1,0		// cancel timer
  Let,1,0		// set user variable 1 to 0
endon
On Rules#Timer=1 do 		// if still no Wifi, reboot
  reboot
endon
Regards,
Rob
BertB
Re: RFLink + Wi-Fi
Post by BertB »
Great, thanks.
ajongen70
Domoticz version: 2024.3
Re: RFLink + Wi-Fi
Post by ajongen70 »
Hi All,
I am experiencing the same issues once in a while. All this with the latest stable Beta of Domoticz installed. The RFLink is pingable and the webpage the ESP8266 provides is working so Wifi connection is all good, but domoticz is disconnected and issuing "Bad address" errors. Restarting the RFLink does not resolve the issue. Trying to disable and re-enable the RFLink LAN hardware in domoticz results in a crash of domoticz. Stopping and restarting domoticz completely is the only resolution.
Did the suggested solution result in a stable system? Or is there something fishy in the RFLink LAN Hardware implementation in Domoticz, since it results in crashing the domoticz process?
Thanks for any help on this issue.
Cheers, Armand
FlyingDomotic
Re: RFLink + Wi-Fi
Post by FlyingDomotic »
Would it be possible to get Domoticz's crash dump?
Even if initial cause is perhaps not in plugin, crashing Domoticz is for sure not normal.
ajongen70
Re: RFLink + Wi-Fi
Post by ajongen70 »
As requested:
domo_crash.log
Domoticz Crash log
(33.18 KiB) Downloaded 513 times
Thanks for looking into this.
FlyingDomotic
Re: RFLink + Wi-Fi
It seems that crash occurs in free memory while disconnecting asynchronous TCP link. this is likely a bug in plugin. Developers can investigate.
Reading crash, it seems also that 2 RFLink sub-processes are present. Could you check that there's no duplicate instances of plugin in "hardware" tab?
ajongen70
Re: RFLink + Wi-Fi
Post by ajongen70 »
I double checked but there is only 1 RFLink Hardware instance present.
timmpo
Re: RFLink + Wi-Fi
Post by timmpo »
i have use 2 rflink gateways in many years now and with latest domoticz one of them always stop responding to domoticz.
Sometimes domoticz crash, and i also suspect it related to the rflink device..
2025-07-26 01:44:47.968  [7f90d97fa6c0] Status: 433mhz Gateway 2 Entre: Trying to connect to 192.168.1.220:6666
2025-07-26 01:44:48.067  [7f90c2ffd6c0] Status: 433mhz Gateway 2 Entre: Connected to: 192.168.1.220:6666
2025-07-26 01:44:48.068  [7f90c2ffd6c0] Error: Domoticz(pid:121999, tid:620086('433mhz Gateway ')) received fatal signal 6 (Aborted)
2025-07-26 01:44:48.068  [7f90c2ffd6c0] Error: siginfo address=0x1dc8f, address=0x7f90fa8a9e3c
2025-07-26 01:44:48.091  [7f90c2ffd6c0] Error: Failed to start gdb, will use backtrace() for printing stack frame
2025-07-26 01:44:48.096  [7f90c2ffd6c0] Error: #0  /home/timmpo/domoticz/domoticz :  + 0x419923 [0x5583351d6923]
2025-07-26 01:44:48.096  [7f90c2ffd6c0] Error: #1  /home/timmpo/domoticz/domoticz : signal_handler(int, siginfo_t*, void*) + 0x29d [0x5583351d740d]
2025-07-26 01:44:48.096  [7f90c2ffd6c0] Error: #2  /lib/x86_64-linux-gnu/libc.so.6 :  + 0x3c050 [0x7f90fa85b050]
2025-07-26 01:44:48.096  [7f90c2ffd6c0] Error: #3  /lib/x86_64-linux-gnu/libc.so.6 :  + 0x8ae3c [0x7f90fa8a9e3c]
2025-07-26 01:44:48.096  [7f90c2ffd6c0] Error: #4  /lib/x86_64-linux-gnu/libc.so.6 : gsignal + 0x12 [0x7f90fa85afb2]
2025-07-26 01:44:48.096  [7f90c2ffd6c0] Error: #5  /lib/x86_64-linux-gnu/libc.so.6 :  + 0x3c050 [0x7f90fa85b050]
2025-07-26 01:44:48.096  [7f90c2ffd6c0] Error: #6  /lib/x86_64-linux-gnu/libc.so.6 :  + 0x8ae3c [0x7f90fa8a9e3c]
2025-07-26 01:44:48.096  [7f90c2ffd6c0] Error: #7  /lib/x86_64-linux-gnu/libc.so.6 : gsignal + 0x12 [0x7f90fa85afb2]
2025-07-26 01:44:48.096  [7f90c2ffd6c0] Error: #8  /lib/x86_64-linux-gnu/libc.so.6 : abort + 0xd3 [0x7f90fa845472]
2025-07-26 01:44:48.096  [7f90c2ffd6c0] Error: #9  /lib/x86_64-linux-gnu/libc.so.6 :  + 0x7f430 [0x7f90fa89e430]
2025-07-26 01:44:48.097  [7f90c2ffd6c0] Error: #10 /lib/x86_64-linux-gnu/libc.so.6 :  + 0x947ba [0x7f90fa8b37ba]
2025-07-26 01:44:48.097  [7f90c2ffd6c0] Error: #11 /lib/x86_64-linux-gnu/libc.so.6 :  + 0x9497c [0x7f90fa8b397c]
2025-07-26 01:44:48.097  [7f90c2ffd6c0] Error: #12 /lib/x86_64-linux-gnu/libc.so.6 : __libc_free + 0xb8 [0x7f90fa8b7ee8]
2025-07-26 01:44:48.097  [7f90c2ffd6c0] Error: #13 /home/timmpo/domoticz/domoticz : ASyncTCP::cb_write_done(boost::system::error_code const&, unsigned long) + 0x48 [0x558335383828]
2025-07-26 01:44:48.097  [7f90c2ffd6c0] Error: #14 /home/timmpo/domoticz/domoticz :  + 0x5c6909 [0x558335383909]
2025-07-26 01:44:48.097  [7f90c2ffd6c0] Error: #15 /home/timmpo/domoticz/domoticz :  + 0x5c6f61 [0x558335383f61]
2025-07-26 01:44:48.097  [7f90c2ffd6c0] Error: #16 /home/timmpo/domoticz/domoticz : boost::asio::detail::scheduler::run(boost::system::error_code&) + 0x4e5 [0x558335370575]
2025-07-26 01:44:48.097  [7f90c2ffd6c0] Error: #17 /home/timmpo/domoticz/domoticz :  + 0x5be5a7 [0x55833537b5a7]
2025-07-26 01:44:48.097  [7f90c2ffd6c0] Error: #18 /home/timmpo/domoticz/domoticz :  + 0xc14070 [0x5583359d1070]
2025-07-26 01:44:48.097  [7f90c2ffd6c0] Error: #19 /lib/x86_64-linux-gnu/libc.so.6 :  + 0x89144 [0x7f90fa8a8144]
2025-07-26 01:44:48.097  [7f90c2ffd6c0] Error: #20 /lib/x86_64-linux-gnu/libc.so.6 :  + 0x1097dc [0x7f90fa9287dc]
gizmocuz
Re: RFLink + Wi-Fi
Post by gizmocuz »
Probably same issue as this:
viewtopic.php?f=6&t=43834
(timmpo could have a fix for this)
ajongen70
Re: RFLink + Wi-Fi
Post by ajongen70 »
A short update from my side: I got a new modem/router from my provider Ziggo / The Netherlands. Since I have the new modem/router in use, I have had no issues anymore. So it might be router (or maybe provider) related and not plugin related.
redfirebrooks
Re: RFLink + Wi-Fi
Post by redfirebrooks »
Hello, I have a similar set up : Arduino mini pro + Aurel mid 5v + ESP01s (firmware : Build: ESP_Easy_mega_20241222_normal_ESP8266_1M Dec 22 2024). Domoticz is feeded correctly through the communication serial Server (It reads all my Oregons devices) but I can't send any command back. They just get lost with the error message "Error sending switch command, check device/hardware (idx=5023) !" for example.
Maybe I messed up some where ?
This is the configuration in ESP EASY : GPIO values : RX: GPIO-3 (D9) - TX: GPIO-1 (D10) - RST: - LED: GPIO-2 (D4) (inv)<
Any clue how to send the 433 commands to the Rflink ?
Version: 2024.1
Build Hash: 5279c8261
Compile Date: 2024-01-01 12:59:22
dzVents Version: 3.1.8
Python Version: 3.9.2
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
