Unable to make switch with the shutter ZMNHCD1
Posted: Saturday 04 July 2020 11:43
by mojojojo490
I have connected a sunshade to the Qubino shutter ZMNHCD1.
It woks fine with the handswitch.
Learning the module in Domoticz worked. I can even change the parameters.
Only I can't learn the switch automaticaly. Also i don't know the settings manual.
How do i fix this?
Re: Unable to make switch with the shutter ZMNHCD1
Posted: Sunday 26 July 2020 19:07
by benp
I have the same problem with ZMNHCD1
It works fine with momentary switch (2 switches momentary connected to I1 and I2) but not remotly.
I want to connect the ZMNHCD1 to a 2 speeds exhaust fan unit(VMC in french). Because it was not working properly I connected 2 light-bulb to Q1 and Q2 to try to understand.
Domoticz recognize 6 devices:
I try to use for device 288:
- Blinds
- Blinds inverted
- ON/OFF (default)
It is only possible to switch the relay connected on I2 from domoticz. It is not possible to switch the relay I1.
Here is my config:
My domoticz version is 2020.2
OZWC is 1.6
My MNHCD1 version : 7 on the box
I use a razberry as zwave controller
Posted: Friday 28 August 2020 14:31
by romaint2b
I've got the same issue. did you find a solution?
Last year, I bought a qubino roller shutter and i add it to my domoticz. I was using the previous version of domoticz (2019).
I use blinds inverted and it works.(not with percentage but i can open / close my shutter with domoticz and with the wall button).
So I decide to include all my shutter (bubendorff 4 wire) and bought 5 new qubino modules (firm v7).
But opening/closing is not working with button or with domoticz....
I try to set motor time to 0 and to 160 (and more) without success.
Next step is to try with paramter 78 ( auto setup..) but i've got no hope.
My conf :
10 : All on and All off
40 : 1
42 : 300
71 : Shutter
72 : 150
73 : Z-wave control,push button, or when limit is reached
74 : 0
76 : 50
78 : Default
85 : 20
90 : 1
110 : 32536
120 : 5
Posted: Friday 28 August 2020 19:42
by benp
I exchanged the ZMNHCD1 with a FGS213(single switch no usable with shutter but ok for exhaust fan unit). This solved the problem for me but not for this topic...
Posted: Saturday 29 August 2020 20:48
by romaint2b
Thank you ;).
I investigate. Qubino MNHCD1 have a bug with firmware version 7.1. If you have 3 button to control your shutter, you must click on central button (not up and not down) to allow qubino to manage your shutter by zwave.
To see it you can go in the ZWave material configuration in domoticz and clic on manage nodes and click on "Panneau de commande" (Control Panel).
Then, you can click the line with your module and select the radio button "Information".
Last line is Application version
7.00 = 7
71.00 = 7.1
