deCONZ and Ikea tradfri E1743
Posted: Wednesday 01 July 2020 22:01
Greetings.
Atm I have a Hue bridge with a few lamps and a few on 433mhz, but I want to add ikeas on/off button to my system.
And have them to set a virtual switch for us when we are going to sleep.
I've installed the ConBee II and got it to work on domoticz, ive also added the button.
But when I turn it on it turns off after 5 sec in domoticz.
Which results to the light to turn on again.
Also when I press the off button, it turns on again for a few seconds resulting on the switch to be as I pressed ON again.
I have the button set as a selector, level 0 are Off and 10 are On.
As a ON/OFF switch it says "Sound 2" for a few sec on on but it dont turn on the light, on off it does nothing as I can see.
How do I make it so that the switch stays on untill i press the off button ??
Is it possible to have it as a normal on and off button??
(deCONZ) ### Device > 3 Name:TRADFRI on/off switch Type:ZHASwitch Details:{'buttonevent': 1002, 'lastupdated': '2020-07-01T19:57:59.824'} and {'alert': 'none', 'battery': 87, 'group': '3', 'on': True, 'reachable': True}
Here are my Domoticz info:
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: 3.7.3 (default, Dec 20 2019, 18:57:59) [GCC 8.3.0]
Runing on a Raspberry 3B
Version: 2020.2
