Page 1 of 28
Python Plugin : Broadlink
Posted: Wednesday 01 July 2020 18:20
by zak45
complete new plugin.
Old version (4.x) could not be upgraded, you need to create a new folder, and import your ini files if you want to use this one.
Info : do not use the official app if using broadlink library
see https://github.com/mjg59/python-broadlink/issues/377
note: pip need to be installed
(for linux users: sudo apt install python3-pip)
To be able to see the Web Pages, Custom menu need to be activated: Domoticz / settings.
Be sure that your active python version is > 3.4 (Change python version system-wide)
this mean: python --version ( or sudo python --version for linux users)
should give output e.g. python 3.x.x and not python 2.x.x
this one : https://linuxconfig.org/how-to-change-f ... bian-linux
Features:
Multi-Language
Multi-Devices (MP1 / A1 / SP1-2-3 / RM2-3 Pro & mini / RM4 Pro & mini
Web Admin page
RF is now managed
Multi-code ini file creation by drag & drop
Create Broadlink ini from Pronto Hex
Create ini from e-Control
Modify number of repetition (do and test with caution)
Import feature
Send code with a simple URL
and more .....
Installation :
create Broadlink directory under your Domoticz/plugins folder.
download setup.py from here : https://raw.githubusercontent.com/zak-4 ... n/setup.py
and put it into Broadlink directory.
Open a terminal session, go to Broadlink directory and execute this command : python setup.py (tested on Windows with admin right, maybe need sudo on linux e.g; : sudo python setup.py)
Provide response to questions.
Restart Domoticz.
Create a new hardware, type : Broadlink with Kodi Remote
Manual installation:
see GitHub
WebAdmin Page overview:
For Devlopers:
this is the port necessary to use MS visual debugger
--> main py : plugin.py
Domoticz.Log('Waiting for MS Visual Studio remote debugger connection ....')
ptvsd.enable_attach(address=('0.0.0.0', 5678))
--> subprocess : Dombroadlink.py
ptvsd.enable_attach(address=('0.0.0.0', 6789))
module ptvsd need to be installed.
Lets try and play with it.
Provide bugs/feedback here.
Enjoy !!
test platform : Windows 10
Version: 2020.2 (build 12120)
Build Hash: ecd90cd57
Compile Date: 2020-06-04 20:50:42
dzVents Version: 3.0.9
Python Version: 3.7.5 (tags/v3.7.5:5c02a39a0b, Oct 14 2019, 23:09:19) [MSC v.1916 32 bit (Intel)]
Re: Python Plugin : Broadlink
Posted: Wednesday 01 July 2020 19:47
by Hogis
I'm getting a syntax error when trying to install on a RaspberryPi:
File "setup.py", line 170
print("\r>> Bytes downloaded -->" + state + str(leng) + state, end='', flush=True)
SyntaxError: invalid syntax
Posted: Wednesday 01 July 2020 19:57
by zak45
Try by removing the line 170.
Posted: Wednesday 01 July 2020 20:07
by Hogis
Now I get:
File "setup.py", line 16, in <module>
import requests
ImportError: No module named requests
Posted: Wednesday 01 July 2020 20:12
by zak45
you need to install the 'requests' module:
should be:
sudo -H python -m pip install requests
these are modules required by the setup.py:
import socket
import os
import sys
import subprocess
import requests
import urllib.request
import urllib.parse
import urllib.error
import json
import traceback
from zipfile import ZipFile
import time
Posted: Thursday 02 July 2020 14:04
by esecamara
pi@raspberrypi:~/domoticz/plugins/Broadlink $ python setup.py
File "setup.py", line 194
Posted: Thursday 02 July 2020 18:58
by zak45
Hogis wrote: Wednesday 01 July 2020 20:07 Now I get:
import requests
I have modified setup.py to change the order installation. just download it and try again.
Posted: Thursday 02 July 2020 20:20
by JUNA
I also experienced the SyntaxError: invalid syntax. After changing python setup.py --> python3 setup.py it was possible to install.
But after restart I get following error:
2020-07-02 20:04:01.351 Error: (Broadlink) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Broadlink/:/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2020-07-02 20:04:01.351 Error: (RM3mini) Module Import failed, exception: 'ModuleNotFoundError'
2020-07-02 20:04:01.351 Error: (RM3mini) Module Import failed: ' Name: requests_toolbelt'
2020-07-02 20:04:01.351 Error: (RM3mini) Error Line details not available.
Any suggestions how to fix this?
Posted: Thursday 02 July 2020 21:14
by zak45
JUNA wrote: Thursday 02 July 2020 20:20 I also experienced the SyntaxError: invalid syntax. After changing python setup.py --> python3 setup.py it was possible to install.
if you need to enter python3 instead python, looks like your python settings are not ok.
if you enter python --version --> what's your output ?
if not 3.x.... you need to change that.. see post below.
Once python v3.x is your default version, just redo setup.py.
Posted: Thursday 02 July 2020 22:58
by zak45
setup.py improved.
final check at the end to help debug.
Posted: Friday 03 July 2020 0:43
by JUNA
zak45 wrote: Thursday 02 July 2020 21:14
I think I have fixed python issue. No errors after running python setup.py.
After reboot log showing errors below. Am I using correct python version or is error caused by something else?
Raspberry Pi 4
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: 3.7.3 (default, Dec 20 2019, 18:57:59) [GCC 8.3.0]
2020-07-03 00:31:00.832 Sunrise: 05:24:00 SunSet: 22:03:00
2020-07-03 00:31:00.832 Day length: 16:39:00 Sun at south: 13:44:00
2020-07-03 00:31:00.832 Civil twilight start: 04:35:00 Civil twilight end: 22:52:00
2020-07-03 00:31:00.832 Nautical twilight start: 03:19:00 Nautical twilight end: 00:08:00
2020-07-03 00:31:00.832 There is no astronomical twilight in the space of 24 hours
2020-07-03 00:31:00.717 Status: Domoticz V2020.2 (c)2012-2020 GizMoCuz
2020-07-03 00:31:00.717 Status: Build Hash: b63341bc0, Date: 2020-04-26 13:47:55
2020-07-03 00:31:00.717 Status: Startup Path: /home/pi/domoticz/
2020-07-03 00:31:01.234 Active notification Subsystems: (0/13)
2020-07-03 00:31:01.275 Starting shared server on: :::6144
2020-07-03 00:31:01.227 Status: PluginSystem: Started, Python version '3.7.3'.
2020-07-03 00:31:01.256 Status: WebServer(HTTP) started on address: :: with port 8080
2020-07-03 00:31:01.272 Status: WebServer(SSL) started on address: :: with port 443
2020-07-03 00:31:01.275 Status: TCPServer: shared server started...
2020-07-03 00:31:01.276 Status: RxQueue: queue worker started...
2020-07-03 00:31:03.276 Status: (RM3m) Started.
2020-07-03 00:31:03.276 Status: NotificationSystem: thread started...
2020-07-03 00:31:03.276 Status: EventSystem: reset all events...
2020-07-03 00:31:03.287 Status: EventSystem: reset all device statuses...
2020-07-03 00:31:03.361 Status: PluginSystem: Entering work loop.
2020-07-03 00:31:03.403 Status: Python EventSystem: Initalizing event module.
2020-07-03 00:31:03.404 Status: EventSystem: Started
2020-07-03 00:31:03.404 Status: EventSystem: Queue thread started...
2020-07-03 00:31:04.443 (RM3m) lang file : /home/pi/domoticz/plugins/Broadlink/lng/en_en.lng
2020-07-03 00:31:04.443 (RM3m) Language loaded for : en
2020-07-03 00:31:04.446 (RM3m) Listen on BROWebServer - Port: 9000
2020-07-03 00:31:04.446 (RM3m) Connecting to: 192.168.1.173 : 24DFA7E01829
2020-07-03 00:31:04.467 (RM3m) Update 0:'Off' (RM3m - RM2-Status)
2020-07-03 00:31:04.481 (RM3m) Plugin Device count start on : 9
2020-07-03 00:31:04.491 (RM3m) Admin html file created: /home/pi/domoticz/www/templates/Broadlink-RM2-2.html
2020-07-03 00:31:04.492 (RM3m) Command line file created: /home/pi/domoticz/plugins/Broadlink/log/2RM2.txt
2020-07-03 00:31:04.438 Status: (RM3m) Entering work loop.
2020-07-03 00:31:04.438 Status: (RM3m) Initialized version 1.0.0, author 'zak45'
2020-07-03 00:31:04.457 Error: (RM3m) Traceback (most recent call last):
2020-07-03 00:31:04.457 File "/home/pi/domoticz/plugins/Broadlink/plugin.py", line 1703, in broadlink_connect
2020-07-03 00:31:04.457 DEVICE.auth()
2020-07-03 00:31:04.457 File "/usr/lib/python3.7/broadlink/__init__.py", line 224, in auth
2020-07-03 00:31:04.457 response = self.send_packet(0x65, payload)
2020-07-03 00:31:04.457 File "/usr/lib/python3.7/broadlink/__init__.py", line 296, in send_packet
2020-07-03 00:31:04.457 cs.sendto(packet, self.host)
2020-07-03 00:31:04.457 OSError: [Errno 101] Network is unreachable
2020-07-03 00:31:04.457 Error: (RM3m) Error to connect to Broadlink device: 192.168.1.173
Posted: Friday 03 July 2020 10:58
by zak45
JUNA wrote: Friday 03 July 2020 0:43 2020-07-03 00:31:04.457 File "/usr/lib/python3.7/broadlink/__init__.py", line 296, in send_packet
Verify your network settings: IP address etc ... maybe firewall blocking.
Posted: Friday 03 July 2020 18:12
by ayasystems
FYI:
Could be better launch directly with python3 if you have python2 and python3 installed
Collecting httpx==0.13.3 (from googletrans)
Could not find a version that satisfies the requirement httpx==0.13.3 (from googletrans) (from versions: )
No matching distribution found for httpx==0.13.3 (from googletrans)
ERROR to start subprocess
Collecting pre-commit (from translate)
Downloading https://www.piwheels.org/simple/pre-com ... ne-any.whl (171kB)
100% |████████████████████████████████| 174kB 1.4MB/s
pre-commit requires Python '>=3.6.1' but the running Python is 2.7.16
at the end of process
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Processing ./python-broadlink-master
Requirement already satisfied: cryptography>=2.1.1 in /usr/lib/python2.7/dist-packages (from broadlink==0.14.0) (2.6.1)
Building wheels for collected packages: broadlink
Running setup.py bdist_wheel for broadlink ... done
Stored in directory: /root/.cache/pip/wheels/64/c9/3d/783a37f13531f3773a98e682962b2b4946ceaeb6fcfece1d46
Successfully built broadlink
Installing collected packages: broadlink
Successfully installed broadlink-0.14.0
We have installed : python-broadlink-master/.
________________________________________
# We do necessary modifications depend of Platform
put *.py files executable (+x) OK
put *.sh files executable (+x) OK
Error importing googletrans
Posted: Friday 03 July 2020 18:27
by ayasystems
When I try to learn a new IR code i get the following error
2020-07-03 17:25:53.807 Status: User: Admin initiated a switch command (14/new-broadlink - IR Commands/Set Level)
2020-07-03 17:25:53.865 Error: (new-broadlink) 'onCommand' failed 'TimeoutExpired'.
2020-07-03 17:25:53.865 Error: (new-broadlink) ----> Line 445 in '/home/pi/domoticz/plugins/Broadlink/plugin.py', function onCommand
2020-07-03 17:25:53.865 Error: (new-broadlink) ----> Line 2294 in '/home/pi/domoticz/plugins/Broadlink/plugin.py', function start_shell
2020-07-03 17:25:53.865 Error: (new-broadlink) ----> Line 342 in '/usr/lib/python3.7/subprocess.py', function check_call
2020-07-03 17:25:53.865 Error: (new-broadlink) ----> Line 329 in '/usr/lib/python3.7/subprocess.py', function call
2020-07-03 17:25:53.865 Error: (new-broadlink) ----> Line 1006 in '/usr/lib/python3.7/subprocess.py', function wait
2020-07-03 17:25:53.865 Error: (new-broadlink) ----> Line 1616 in '/usr/lib/python3.7/subprocess.py', function _wait
2020-07-03 17:25:57.387 (new-broadlink) Connected to Broadlink device: 192.168.3.97 RM2
2020-07-03 17:25:57.398 (new-broadlink) Update 1:'On' (new-broadlink - RM2-Status)
If you want access to a raspberry to test it into this environment i can provide it for you, let me know
Posted: Friday 03 July 2020 20:58
by zak45
ayasystems wrote: Friday 03 July 2020 18:12
by settings python3 as default system wide version, you should avoid lot's of problem, I think, specially if you use your system mainly for Domoticz.
Posted: Friday 03 July 2020 21:01
by zak45
ayasystems wrote: Friday 03 July 2020 18:27 When I try to learn a new IR code i get the following error
1: I suppose the problem is from dombr.sh , put plugin on debug mode to have more information...
2 : thanks for the proposal, if necessary will come back to you !!!
Posted: Friday 03 July 2020 22:57
by JUNA
zak45 wrote: Friday 03 July 2020 10:58
Fixed firewall issue (Pi-Hole)...
Now I have a new issue:
2020-07-03 22:50:06.303 Error: (RM4m) Traceback (most recent call last):
2020-07-03 22:50:06.303 File "/home/pi/domoticz/plugins/Broadlink/plugin.py", line 1703, in broadlink_connect
2020-07-03 22:50:06.303 DEVICE.auth()
2020-07-03 22:50:06.303 File "/usr/lib/python3.7/broadlink/__init__.py", line 225, in auth
2020-07-03 22:50:06.303 check_error(response[0x22:0x24])
2020-07-03 22:50:06.303 File "/usr/lib/python3.7/broadlink/exceptions.py", line 97, in check_error
2020-07-03 22:50:06.303 raise exception(error_code)
2020-07-03 22:50:06.303 broadlink.exceptions.AuthenticationError: Authentication failed
2020-07-03 22:50:06.304 Error: (RM4m) Error to connect to Broadlink device: 192.168.1.172
Posted: Friday 03 July 2020 23:07
by zak45
JUNA wrote: Friday 03 July 2020 22:57 Now I have a new issue:
if your device is connected to the official app, see this link:
Posted: Saturday 04 July 2020 9:55
by JUNA
zak45 wrote: Friday 03 July 2020 23:07
Thank you! With the "new" Broadlink app I first had to set device in AP mode. In AP mode led flashed not continuously which was a bit confusing.
Broadlink AP mode
Broadlink AP mode
Posted: Saturday 04 July 2020 9:58
by JUNA
zak45 wrote: Friday 03 July 2020 21:01
Same error here. How can I set plugin in debug mode?
