Heatit Z-TRM3 thermostat
Posted: Tuesday 30 June 2020 18:45
by DeVille70
Has anyone been able to install the Heatit Z-TRM3 thermostat? I tried, but with no success.
Re: Heatit Z-TRM3 thermostat
Posted: Monday 06 July 2020 11:56
by Yabby
I just swapped my Z-TRM2 for 3, i did install them but there is an issue with the setpoint, which cannot be set. It seems to be affecting all the system based on open z-wave. Apparently an issue on the format of the command. It seems widespread in the forums
Posted: Tuesday 28 July 2020 18:34
by DeVille70
Thanks. Did it include correctly? I get a number of devices, but no configuration options at all of the Z-Wave node. That makes me suspect it did not include correctly, or I use the wrong xml file.
Posted: Monday 24 August 2020 14:35
by Yabby
Yes I managed to include it correctly
Posted: Thursday 26 November 2020 13:41
by Zweezo
Is this still an issue or is the Heat It Z-TRM3 fully functional in Domoticz?
Posted: Wednesday 16 December 2020 17:21
by Geitje
I have this exact same problem. Inclusion if fine, but I cannot set the setpoint from Domoticz. The setpoint is reported fine if I change it on the device itself.
How have others resolved this?
Posted: Tuesday 29 December 2020 11:10
by Emmerich
Thanks for the update and quick reply. I'll be sure to keep an eye on this thread. Looking for the same issue.
MyFordBenefits Login
Posted: Tuesday 29 December 2020 23:56
by Geitje
I found this on Github:
https://github.com/OpenZWave/open-zwave/pull/2458
So it seems a OpenZwave issue, so little to do with Domoticz. Let's just wait until thay merge the pull request on Github...
