Strange behaviour with graphs after last update
Posted: Saturday 27 June 2020 22:28
by madradrakie
I experience some very strange behaviour with my dashticz graphs after the latest beta updates. It started after updating to beta version 3.4.6. Dashticz is running on an apple ipad with the latest IOS. It is running in fullscreen with the safari webbrowser and was always working perfectly. Since the upgrade the graphs are shown after i start dashticz in saferi, but after about 2 hours the graphs are not shown anymore. When i press at the screen at the place where the graph should be displayed, i see that dashticz still receives information form domoticz (see screenshot) but the graphs are not shown anymore.
Now i first have to shutdown saferi completley (kill the app) and after restart of dashticz the graphs are shown again.
Does anybody know what the issue could be? Thanks in advance
- Knipsel.JPG (69.19 KiB) Viewed 2206 times
Re: Strange behaviour with graphs after last update
Posted: Thursday 23 July 2020 16:39
by madradrakie
also after upgrading to the latest beta still no luck en still the same problem that after about 3 hours de graphs disappear?
I also started with a clean install and only implemented the graph in dashtich but still no luck.
Any other ideas are more than welcome.
Posted: Saturday 01 August 2020 14:16
by Lokonli
I'll do some more testing on my iPad and will let you know the results.
In the mean time: can you test with Dashticz standby disabled, and a very high value for dashticz_refresh?
Posted: Tuesday 04 August 2020 7:32
by madradrakie
i will disable dashticz standy this evening and do some testing. I already changed the refreshing rate to 4800sec. I lett you know my results. Thanks for your help!
Posted: Tuesday 01 February 2022 8:50
by Mirkoser
Hello any news on this topic? I’m running the latest beta of dashticz and I have the same issue on my iPad. I assume it could be the safari browser itself?
Or any orher ideas?
Posted: Wednesday 02 February 2022 21:44
by Lokonli
Is the issue you have exactly the same as described by the topic starter?
Is the screen of your iPad always on, or is the screen disabled after a while?
Posted: Wednesday 02 February 2022 21:57
by Mirkoser
Hi screen is always on. Yes exactly the same behavior. Data in the background available but graph not visible. I tested on another iPad and different browser. Same result. Also tried to increase refreshing rate, standby is off. And I can just solve it by killing safari app. Refreshing the link is not enough. Really annoying… will post my config tomorrow. Maybe I missed anything in the config
Posted: Wednesday 02 February 2022 22:30
by Lokonli
ok, I'll try to reproduce the issue coming night on my ipad. Let's see what happens...
Posted: Thursday 03 February 2022 21:14
by Mirkoser
here my config
var config = {}
config['domoticz_ip'] = 'http://192xxxx;
config['user_name'] = 'xxxxx';
config['pass_word'] = 'xxxxxx';
config['app_title'] = 'Unser Heim';
config['domoticz_refresh'] = 5;
config['dashticz_refresh'] = 240;
config['login_timeout'] = 9999;
config['loginEnabled'] = false;
config['pass_word'] ='';
config['user_name'] ='';
config['use_favorites'] = 0;
config['auto_positioning'] = 0;
config['language'] = 'de_DE';
config['background_image'] = 'img/bg14.jpg';
config['start_page'] = 1;
config['auto_swipe_back_to'] = 0;
config['auto_swipe_back_after'] = 0;
config['standby_after'] = 0;
config['slide_effect'] = 'fade';
config['standard_graph'] = 'day';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'de_DE';
config['last_update'] = 0;
config['boss_stationcloc'] = 'BlackBoss';
config['edit_mode'] = 0;
config['use_cors'] = 0;
config['theme'] = 'default';
config['speak_lang'] = 'de-DE';
config['owm_api'] = 'd3958d5f0fd887612c57117dc1907769';
config['owm_city'] = 'Marklohe';
config['owm_name'] = 'Lemke';
config['owm_country'] = 'de';
config['owm_lang'] = 'de';
config['owm_cnt'] = '4';
config['owm_min'] = true;
config['owm_days'] = true;
config['switch_horizon'] = 0;
config['loginEnabled'] = 0;
config['disable_update_check'] = 0;
config['hide_topbar'] = 0;
config['security_button_icons'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['enable_websocket'] = true;
config['auto_slide_pages']=0;
config['batteryThreshold']= 75;
and here the graphs
//Graph
blocks['graph_1066'] = {
devices: [1066],
title: 'Gesamtwärmeerzeugung',
graph: 'bar',
height: '200px',
spanGaps: true,
legend: false,
datasetColors: ['rgb(60,20,232)'],
blocks['graph_1429'] = {
title: 'aktuelle PV Leistung',
width: 12,
devices: [1429],
graph: 'line',
lineFill : true,
height: '180px',
beginAtZero: true,
spanGaps: true,
legend: false,
maxTicksLimit: 15,
datasetColors: ['rgb(255,255,102)'],
options: {
scales: {
yAxes: [{
ticks: {
min: 0,
blocks['graph_1041'] = {
title: ['Verdichterfrequenz','Gradminuten'],
width: 12,
devices: [1041,1024],
graph: ['bar','line'],
height: '500px',
maxTicksLimit: 25,
datasetColors: ['rgb(60,20,232)','rgb(255,0,0)'],
legend: {
'v_1041' : 'Verdichterfrequenz',
'v_1024' : 'Gradminuten',
blocks['graph_1020'] = {
title: 'Außentemperatur',
width: 12,
graph: 'line',
height: '200px',
maxTicksLimit: 10,
Posted: Friday 04 February 2022 8:23
by Mirkoser
maybe also the custum .css has an impact on that behaviour?
CUSTOM CSS FILE
.titlegroups {background-color: black !important;}
div.mh.titlegroups {
height: 55px !important;
padding-top: 3px;
.titlegroups[data-id='blocktitle_10'] {background-color: grey !important;}
.titlegroups[data-id='blocktitle_10'] h3 {
font-size: 17px;
div.mh.titlegroups[data-id='blocktitle_10'] {
height: 40px !important;
padding-top: 1px;
.titlegroups[data-id='blocktitle_11'] {background-color: grey !important;}
.titlegroups[data-id='blocktitle_11'] h3 {
font-size: 17px;
div.mh.titlegroups[data-id='blocktitle_11'] {
padding-top: 1px;
.titlegroups[data-id='blocktitle_12'] {background-color: grey!important;}
.titlegroups[data-id='blocktitle_12'] h3 {
font-size: 17px;
div.mh.titlegroups[data-id='blocktitle_12'] {
padding-top: 1px;
.titlegroups[data-id='blocktitle_13'] {background-color: grey!important;}
.titlegroups[data-id='blocktitle_13'] h3 {
font-size: 17px;
div.mh.titlegroups[data-id='blocktitle_13'] {
padding-top: 1px;
.titlegroups[data-id='blocktitle_14'] {background-color: grey!important;}
.titlegroups[data-id='blocktitle_14'] h3 {
font-size: 17px;
div.mh.titlegroups[data-id='blocktitle_14'] {
padding-top: 1px;
.titlegroups[data-id='blocktitle_15'] {background-color: grey!important;}
.titlegroups[data-id='blocktitle_15'] h3 {
font-size: 17px;
div.mh.titlegroups[data-id='blocktitle_15'] {
padding-top: 1px;
[data-id='graph_1066'] .graphbuttons {
display: none;
[data-id='graph_1429'] .graphbuttons {
display: none;
[data-id='graph_1041'] .graphbuttons {
display: none;
[data-id='graph_1024'] .graphbuttons {
display: none;
[data-id='graph_1020'] .graphbuttons {
display: none;
.fas.fa-lightbulb {
color:#F1C300;
.far.fa-lightbulb {
color:#fff;
.transbg[class*="col-xs"] {
border: 3px solid rgba(255,255,255,0);
Here a picture from the dashboard
![Image]()
Posted: Friday 04 February 2022 12:57
by Lokonli
I did a test with my iPad and it was running without issues for 24 hours.
I'm using iOS 10 (old iPad).
I'm not sure what's going wrong. I propose to test with
Currently, you have this set to 240, which is 4 hours, meaning Dashticz will refresh after 4 hours. Maybe something goes wrong with that.
Posted: Sunday 06 February 2022 9:32
by Mirkoser
strange. did not fix the problem. I will do some more test with the custom . css
Posted: Monday 14 February 2022 14:59
by Mirkoser
so here some more input. its getting stranger...so the graph disappear after a couple of hours as i already mentioned but if i do nothing it returns after a couple of hours....and so on ...
Any idea ?
Posted: Monday 14 February 2022 21:40
by Lokonli
Mirkoser wrote: Monday 14 February 2022 14:59
Any idea ?
Domoticz itself is stable?
Still I would guess it relates to the Dashticz refresh.
Can you add:
Dashticz should refresh every minute. Are the graphs updated correctly with this?
Posted: Tuesday 15 February 2022 11:33
by Mirkoser
Same behavior. It refreshes and after some hours the graphs disappear and appear again ( refreshing does not help to make the graph visible)
Posted: Wednesday 16 February 2022 13:43
by Lokonli
Mirkoser wrote: Tuesday 15 February 2022 11:33
Can it be that Domoticz is restarting? What is the Domoticz up time?
Posted: Wednesday 27 April 2022 23:06
by Mirkoser
Finally I found the reason. It was a sensor of my heatpump that did not work correctly and caused these graph abnormalities
