Trying to turn on two lights with a rolling timer based on movement
Posted: Friday 26 June 2020 23:51
by frizby66
Hi..this works, but the timer doesn't restart each time there is movement..it does 1 minute then quickly turns off then back on again (assuming movement is constant). Got brain freeze on how to make it work...or maybe need to use a different option?
Screenshot 2020-06-26 at 22.49.21.png (81.2 KiB) Viewed 583 times
Re: Trying to turn on two lights with a rolling timer based on movement
Posted: Thursday 16 July 2020 16:50
by knielen
This is not possible with Blockly, you need to switch to dzvents for this to work.
Posted: Saturday 18 July 2020 22:19
by wouterlet
Why do you use the timer? Just let the light switch on with movement. When the pir goes off again the light switches off. You can change the "on" time in the setting of the pir
