I have one CO sensor FGCD-001 and three smoke sensors FGSD-002.
The home security switch is continuously on for the CO sensor and two of the smoke sensors. In addition the Power management and result switches for the CO sensor are continuously on. Does the system have a possibility to turn these switches off.
I tried by activating the malfunction detection, but this only activated the Carbon Monoxide switch. Pressing the 'b' button three times turned off the Carbon Monoxide switch, but not the others.
I saw the same being reported in https://www.domoticz.com/forum/viewtopi ... 24&t=15831, but unfortunately no answer was posted there.
Does anybody have a clue for this issue?
Gerben
Fibaro FGCD-001 and FGSD-002 continuous alert
nschoot
- Domoticz version: 4.11590
Re: Fibaro FGCD-001 and FGSD-002 continuous alert
What you can do (I did this for my motion detector which doesn't go to OFF after detecting something) is use the "Uitschakelvertraging" (not sure the english name, "Switch off delay"?. This is in the settings of the switch.
Switches of type Smoke Detector don't have this for some reason, but you could change the switch type to On/Off
Using Zwave, Philips Hue, Raspberry Pi, Machinon Theme
