Zigbee2Mqtt control panel not loading [solved]
Posted: Thursday 25 June 2020 13:00
After I added a IKEA sensor I can't access the control panel.
just stands like this
I get this in the log
I have restarted the RPI,
Updated files from github both Zigbee2Mqtt and the plugin
Restarted the domoticz service.
Restarted the Zigbee2Mqtt service
Disabled en enabled the plugin in the hardware page
Tested in another browser
Solved by
2020-06-25 14:39:19.008 (zigbee2mqtt) Debug logging mask set to: PYTHON PLUGIN DEVICE CONNECTION MESSAGE
2020-06-25 14:39:19.008 (zigbee2mqtt) onStart called
2020-06-25 14:39:19.008 (zigbee2mqtt) Installing plugin custom page...
2020-06-25 14:39:19.009 (zigbee2mqtt) Copying files from /home/pi/domoticz/plugins/zigbee2mqtt/frontend to /home/pi/domoticz/www/templates
2020-06-25 14:39:19.054 (zigbee2mqtt) Installing plugin custom page completed.
2020-06-25 14:39:19.055 (zigbee2mqtt) MqttClient::__init__
2020-06-25 14:39:19.055 (zigbee2mqtt) MqttClient::open
2020-06-25 14:39:19.055 (zigbee2mqtt) Creating device 'Zigbee2MQTT API Transport'.
2020-06-25 14:39:19.059 (zigbee2mqtt) Debug logging mask set to: PYTHON
2020-06-25 14:39:19.059 (zigbee2mqtt) onStart called
2020-06-25 14:39:19.059 (zigbee2mqtt) Installing plugin custom page...
2020-06-25 14:39:19.060 (zigbee2mqtt) Copying files from /home/pi/domoticz/plugins/zigbee2mqtt/frontend to /home/pi/domoticz/www/templates
2020-06-25 14:39:19.120 (zigbee2mqtt) Installing plugin custom page completed.
2020-06-25 14:39:19.120 (zigbee2mqtt) MqttClient::__init__
2020-06-25 14:39:19.121 (zigbee2mqtt) MqttClient::open
2020-06-25 14:39:19.121 (zigbee2mqtt) Protocol set to: 'MQTT'.
2020-06-25 14:39:19.121 (zigbee2mqtt) Transport set to: 'TCP/IP', 127.0.0.1:1883.
2020-06-25 14:39:19.122 (zigbee2mqtt) Connect directive received, action initiated successfully.
2020-06-25 14:39:19.173 (zigbee2mqtt) onConnect called
2020-06-25 14:39:19.173 (zigbee2mqtt) Connected to MQTT Server: 127.0.0.1:1883
2020-06-25 14:39:19.173 (zigbee2mqtt) MQTT CLIENT ID: 'Domoticz_1593088759_7623'
2020-06-25 14:39:19.173 (zigbee2mqtt) MQTT CLIENT ID: 'Domoticz_1593088759_7207'
2020-06-25 14:39:19.173 (zigbee2mqtt) Sending 38 bytes of data
2020-06-25 14:39:19.173 (zigbee2mqtt) 10 24 00 04 4d 51 54 54 04 02 00 3c 00 18 44 6f 6d 6f 74 69 .$..MQTT...<..Domoti
2020-06-25 14:39:19.174 (zigbee2mqtt) 63 7a 5f 31 35 39 33 30 38 38 37 35 39 5f 37 36 32 33 .. .. cz_1593088759_7623
2020-06-25 14:39:19.224 (zigbee2mqtt) Received 4 bytes of data
2020-06-25 14:39:19.224 (zigbee2mqtt) 20 02 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....
2020-06-25 14:39:19.225 (zigbee2mqtt) MqttClient::subscribe
2020-06-25 14:39:19.225 (zigbee2mqtt) Sending 27 bytes of data
2020-06-25 14:39:19.225 (zigbee2mqtt) 82 19 00 01 00 14 7a 69 67 62 65 65 32 6d 71 74 74 2f 62 72 ®....zigbee2mqtt/br
2020-06-25 14:39:19.225 (zigbee2mqtt) 69 64 67 65 2f 23 00 .. .. .. .. .. .. .. .. .. .. .. .. .. idge/#.
2020-06-25 14:39:19.276 (zigbee2mqtt) Received 5 bytes of data
2020-06-25 14:39:19.276 (zigbee2mqtt) 90 03 00 01 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Ю...
2020-06-25 14:39:19.276 (zigbee2mqtt) Received 35 bytes of data
2020-06-25 14:39:19.276 (zigbee2mqtt) 31 21 00 18 7a 69 67 62 65 65 32 6d 71 74 74 2f 62 72 69 64 1!..zigbee2mqtt/brid
2020-06-25 14:39:19.276 (zigbee2mqtt) 67 65 2f 73 74 61 74 65 6f 66 66 6c 69 6e 65 .. .. .. .. .. ge/stateoffline
2020-06-25 14:39:19.276 (zigbee2mqtt) Received 238 bytes of data
2020-06-25 14:39:19.277 (zigbee2mqtt) 31 eb 01 00 19 7a 69 67 62 65 65 32 6d 71 74 74 2f 62 72 69 1뮮.zigbee2mqtt/bri
2020-06-25 14:39:19.277 (zigbee2mqtt) 64 67 65 2f 63 6f 6e 66 69 67 7b 22 76 65 72 73 69 6f 6e 22 dge/config{"version"
2020-06-25 14:39:19.277 (zigbee2mqtt) 3a 22 31 2e 31 34 2e 30 22 2c 22 63 6f 6d 6d 69 74 22 3a 22 :"1.14.0","commit":"
2020-06-25 14:39:19.277 (zigbee2mqtt) 39 30 30 39 64 65 32 22 2c 22 63 6f 6f 72 64 69 6e 61 74 6f 9009de2","coordinato
2020-06-25 14:39:19.277 (zigbee2mqtt) 72 22 3a 7b 22 74 79 70 65 22 3a 22 7a 53 74 61 63 6b 31 32 r":{"type":"zStack12
2020-06-25 14:39:19.277 (zigbee2mqtt) 22 2c 22 6d 65 74 61 22 3a 7b 22 74 72 61 6e 73 70 6f 72 74 ","meta":{"transport
2020-06-25 14:39:19.277 (zigbee2mqtt) 72 65 76 22 3a 32 2c 22 70 72 6f 64 75 63 74 22 3a 30 2c 22 rev":2,"product":0,"
2020-06-25 14:39:19.277 (zigbee2mqtt) 6d 61 6a 6f 72 72 65 6c 22 3a 32 2c 22 6d 69 6e 6f 72 72 65 majorrel":2,"minorre
2020-06-25 14:39:19.277 (zigbee2mqtt) 6c 22 3a 36 2c 22 6d 61 69 6e 74 72 65 6c 22 3a 33 2c 22 72 l":6,"maintrel":3,"r
2020-06-25 14:39:19.277 (zigbee2mqtt) 65 76 69 73 69 6f 6e 22 3a 32 30 31 39 30 34 32 35 7d 7d 2c evision":20190425}},
2020-06-25 14:39:19.277 (zigbee2mqtt) 22 6c 6f 67 5f 6c 65 76 65 6c 22 3a 22 69 6e 66 6f 22 2c 22 "log_level":"info","
2020-06-25 14:39:19.277 (zigbee2mqtt) 70 65 72 6d 69 74 5f 6a 6f 69 6e 22 3a 74 72 75 65 7d .. .. permit_join":true}
2020-06-25 14:39:19.278 (zigbee2mqtt) onMQTTSubscribed
2020-06-25 14:39:19.278 (zigbee2mqtt) MQTT message: zigbee2mqtt/bridge/state offline
2020-06-25 14:39:19.278 (zigbee2mqtt) Zigbee2mqtt bridge is offline
2020-06-25 14:39:19.279 (zigbee2mqtt) MQTT message: zigbee2mqtt/bridge/config {'version': '1.14.0', 'commit': '9009de2', 'coordinator': {'type': 'zStack12', 'meta': {'transportrev': 2, 'product': 0, 'majorrel': 2, 'minorrel': 6, 'maintrel': 3, 'revision': 20190425}}, 'log_level': 'info', 'permit_join': True}
2020-06-25 14:39:19.279 (zigbee2mqtt) Zigbee2mqtt log level is info
2020-06-25 14:39:19.279 (zigbee2mqtt) Joining new devices is enabled on the zigbee bridge
2020-06-25 14:39:19.279 (zigbee2mqtt) onMQTTSubscribed
2020-06-25 14:39:19.280 (zigbee2mqtt) MQTT message: zigbee2mqtt/bridge/state offline
2020-06-25 14:39:19.280 (zigbee2mqtt) Zigbee2mqtt bridge is offline
2020-06-25 14:39:19.280 (zigbee2mqtt) MQTT message: zigbee2mqtt/bridge/config {'version': '1.14.0', 'commit': '9009de2', 'coordinator': {'type': 'zStack12', 'meta': {'transportrev': 2, 'product': 0, 'majorrel': 2, 'minorrel': 6, 'maintrel': 3, 'revision': 20190425}}, 'log_level': 'info', 'permit_join': True}
2020-06-25 14:39:19.280 (zigbee2mqtt) Zigbee2mqtt log level is info
2020-06-25 14:39:19.280 (zigbee2mqtt) Joining new devices is enabled on the zigbee bridge
2020-06-25 14:39:19.055 Error: (zigbee2mqtt) Device creation failed, Domoticz settings prevent accepting new devices.
2020-06-25 14:39:19.121 Error: (zigbee2mqtt) Device creation failed, Domoticz settings prevent accepting new devices.Updated files from github both Zigbee2Mqtt and the plugin
Solved by
andclaude2666 wrote: Sunday 31 October 2021 10:38 To make the Zigbee plugin menu work again, you need to set the api_transport device created in the devices menu to used.![]()
siklosi wrote: Sunday 31 October 2021 11:09 Thanks it's working when api_transport was added. Just a note... you can rename device and add $ to beginning to hide it and it will still work.
