In have just added a Aeotech Z-Wave USB stick to Domoticz and connected a Aeotec Doorbell 6 to it. The connection was successful and using the latest Domoticz version (2020.2 (build 12184)) I get several On/Off switches in Domoticz for the Aeotec Doorbell. When I press the switches in Domoticz the doorbell rings so Z-Wave communication is working.
I have Domoticz connected to Homebridge using the Edomoticz plugin and the On/Off switches from the Aeotec Doorbell appear in Homebridge. The problem now is that the switch status from Domoticz is not being updated / reflected in Homebridge.
Example: when someone rings the doorbell I can see the On/Off switch in Domoticz with label "Doorbell 1 Tones" change status to On and then to Off. This status change however is not visible in Homebridge. Also pressing the switch in Domoticz rings the bell but pressing that same switch in Homebridge does nothing.
I am running the lastest version of Homebridge, Domoticz and Edomoticz plugin. This is all running on a Raspberry Pi 3B which is also completely up to date and I have rebooted it several times. I also removed all the cached accessories in Homebridge. After a reboot all the switches from Domoticz show up again in Homebridge but with no change in behaviour. Still the switch status update for the Aeotec Doorbell 6 is not reflected in Homebridge. All help is greatly appreciated.
Z-Wave Switch status not updating in Homebridge using Edomoticz plugin
