SolarEgde web API
Posted: Tuesday 23 June 2020 20:38
by Jussi1112
Recently I've installed my Raspberry with a fresh image and installed Domoticz with the latest version. I'm able to add SolarEdge hardware, but there doesn't appear any devices.
- Wget https://monitoringapi.solaredge.com/sit ... y=<API-key> on the Raspberry give me the information about my SolarEdge installation, so I'm really sure it is the right API key.
- In Domoticz I've used the hardware "SolarEdge via web API", give it a name, and put in only the API key.
- Using the API from Darksky works without any problems. Also, my P1 meter hardware function fine.
- I've changed the API in the SolarEdge portal
- Rebooted the Raspberry several times
Does anyone have a suggestion to let this API works? In the past, it working without any problems.
Re: SolarEgde web API
Posted: Wednesday 24 June 2020 3:04
by Alain
I see you are posting this question in the evening. Could it be that your PV system wasn't producing at the time you added it to Domoticz? If so, wait until tomorrow. Once your PV system starts producing, you should see numbers appearing on your dashboard.
Posted: Wednesday 24 June 2020 8:01
by Jussi1112
Thanks you Alain for your reply. But I'm struggling already a couple of days with it. And the next day the devices don't appear.
Posted: Wednesday 24 June 2020 9:44
by jvdz
Did you enable "Accept new hardware devices" in the System settings page for a while?
Jos
Posted: Thursday 25 June 2020 21:04
by Jussi1112
Yes, "accept new hardware devices" is enabled. And I've several times activated "accept new hardware for a while". Thanks
Posted: Thursday 25 June 2020 23:52
by McMelloW
Have a SolarEdge Inverter myself. Never got this Hardware devices working.
Have a look at this topics with working solutios.
https://www.domoticz.com/forum/viewtopi ... 38&t=32742
https://www.domoticz.com/forum/viewtopi ... 65&t=31455
Posted: Wednesday 01 July 2020 9:41
by EddyG
I am using this SolarEdge web API for years now.
Most of the time (99%) it is working fine.
Lately I have a lot of errors, see https://www.domoticz.com/forum/viewtopi ... 8&p=251281
It looks like the site is giving a lot of 504 errors.
Posted: Sunday 26 July 2020 18:43
by Jasper79
I installed the Solaredge plug in this morning and it does not read the current watt, I do not see the sensor.
Posted: Saturday 01 August 2020 10:24
by madpatrick
You will indeed not see this value in the devices list
If you add the button as used in your menu, you will see the current value (at least in my setup.....)
Posted: Saturday 01 August 2020 13:36
by Jasper79
Thanks that works. As you can tell I'm by now pretty new to domoticz :mrgreen:
Posted: Tuesday 18 August 2020 19:53
by CharlieJeit
Extract same problem with new setup - no devices. API key works directly fine. No devices no matter how long I wait. No clues in log file.
It is a 3 Phase Invertor - could this be relevant?
Posted: Tuesday 29 December 2020 16:36
by goudgele
For me the issue was that I had not set my location or that dzEvents were not enabled. After setting this and enabling the events, it worked for me.
Posted: Wednesday 20 January 2021 23:21
by mistysnip
I followed instructions to the best of my knowledge and I still don't see SolarEdge hardware in the list.
I'm using the API and I can use my power consumption and, how much the solar panels are producing (if producing more than consumption).
What am I missing?
Thank you
Posted: Friday 22 January 2021 10:19
by elektron16
@Mistysnip I had the same problem but the solution from "goudgele" also did it for me:
Setup --> settings, on the "system" tab you have an option "Location" give your address in the location finder so it is populated with your coordinates.
Then just wait till you solar panels get some sun and create power.
edit:
Don't ask me why it was needed but seems to be a bug? It didn't poll until these location settings were set.
Posted: Monday 22 February 2021 14:45
by Tonyticz
This was also for me the tip to get it running!
Posted: Monday 22 February 2021 15:30
I have added your findings about setting the location to the Solar edge Wiki page:
https://www.domoticz.com/wiki/SolarEdge
Posted: Thursday 22 April 2021 9:21
by jjnh
In the past 2 days Domoticz is not showing the kWh anymore.
Anyone else getting this result?
Posted: Thursday 22 April 2021 10:51
Did you update Domoticz and cleared your browser cache? https://www.domoticz.com/wiki/Browser_Cache
