Refresh zwave device properties
Golgautier
Post by Golgautier »
I had a Qubino device under my domoticz... But I had a (bit) old version of openzwave, and there had an issue in manufacturer_specific.xml file for Qubino brand. So, My device was added as an unknown device. I have updated domoticz and manufacturer_specific file is now right. How can I refresh zwave properties of my device ? With exclusion & inclusion ? There is a more simple procedure ?
Regards.
Derik
Re: Refresh zwave device properties
Post by Derik »
Perhaps remove and include again?
What device do you have? [ Qubino device ? ]
Golgautier
It is a Qubino Flush Shutter...
I found the answer 2mn ago : I deleted my zwcfg_*.xml in my Config file and restarted Domoticz, that has forced full Zwave device refresh...
Deydier
Post by Deydier »
The only way it worked for me was : excluding and including the node FROM Domoticz "Node Management" menu (and NOT using the AEON Z-Wave Z-Stick button)
Deleting zwcfg_*.xml has never worked for me.
Derik
Post by Derik »
stop domoticz:
sudo service domoticz.sh stop
wait ...
login with winscp
search zwcfg
search you node
delete the node from <<Node id="xxx" until </node>
SAVE
and restart Domoticz:
sudo service domoticz.sh start
Then check of the node is there in your zwcfg.xx ..[ refresh..]
When the node is there, do this again.
When it is gone. oke.
If you see the node after this in Domoticz....
Remove it there and do a reboot....
