PiMonitor
Posted: Thursday 18 June 2020 21:38
by Captain
Earlier today, I added PIMonitor - latest version from git hub to my v4.11786 install of (Docker)Domoticz on a raspberry pi 3B+. Of the 17 devices created only, CPU temp amd CPU count have any data - the remainder are all blank or zero. Here are the log messages that are repeated every minute or so. Do you have any suggestions on how to troubleshoot this issue? Thanks
2020-06-18 15:33:53.323 (PiMonitor) Pushing 'onHeartbeatCallback' on to queue
2020-06-18 15:33:53.368 (PiMonitor) Processing 'onHeartbeatCallback' message
2020-06-18 15:33:53.369 (PiMonitor) Calling message handler 'onHeartbeat'.
2020-06-18 15:33:53.369 (PiMonitor) onHeartbeat
2020-06-18 15:33:53.370 (PiMonitor) onHeartbeat called, run again in 5 heartbeats.
2020-06-18 15:34:03.325 (PiMonitor) Pushing 'onHeartbeatCallback' on to queue
2020-06-18 15:34:03.341 (PiMonitor) Processing 'onHeartbeatCallback' message
2020-06-18 15:34:03.341 (PiMonitor) Calling message handler 'onHeartbeat'.
2020-06-18 15:34:03.342 (PiMonitor) onHeartbeat
2020-06-18 15:34:03.342 (PiMonitor) onHeartbeat called, run again in 4 heartbeats.
2020-06-18 15:34:13.328 (PiMonitor) Pushing 'onHeartbeatCallback' on to queue
2020-06-18 15:34:13.364 (PiMonitor) Processing 'onHeartbeatCallback' message
2020-06-18 15:34:13.365 (PiMonitor) Calling message handler 'onHeartbeat'.
2020-06-18 15:34:13.365 (PiMonitor) onHeartbeat
2020-06-18 15:34:13.365 (PiMonitor) onHeartbeat called, run again in 3 heartbeats.
2020-06-18 15:34:23.330 (PiMonitor) Pushing 'onHeartbeatCallback' on to queue
2020-06-18 15:34:23.336 (PiMonitor) Processing 'onHeartbeatCallback' message
2020-06-18 15:34:23.336 (PiMonitor) Calling message handler 'onHeartbeat'.
2020-06-18 15:34:23.337 (PiMonitor) onHeartbeat
2020-06-18 15:34:23.337 (PiMonitor) onHeartbeat called, run again in 2 heartbeats.
2020-06-18 15:34:33.333 (PiMonitor) Pushing 'onHeartbeatCallback' on to queue
2020-06-18 15:34:33.359 (PiMonitor) Processing 'onHeartbeatCallback' message
2020-06-18 15:34:33.359 (PiMonitor) Calling message handler 'onHeartbeat'.
2020-06-18 15:34:33.360 (PiMonitor) onHeartbeat
2020-06-18 15:34:33.360 (PiMonitor) onHeartbeat called, run again in 1 heartbeats.
2020-06-18 15:34:43.335 (PiMonitor) Pushing 'onHeartbeatCallback' on to queue
2020-06-18 15:34:43.381 (PiMonitor) Processing 'onHeartbeatCallback' message
2020-06-18 15:34:43.381 (PiMonitor) Calling message handler 'onHeartbeat'.
2020-06-18 15:34:43.381 (PiMonitor) onHeartbeat
2020-06-18 15:34:43.381 (PiMonitor) CPU count .........: 4
2020-06-18 15:34:43.395 (PiMonitor) CPU temp ..........: 41.9 °C
2020-06-18 15:34:43.396 (PiMonitor) cmd: /opt/vc/bin/vcgencmd measure_temp
2020-06-18 15:34:43.407 (PiMonitor) res:
2020-06-18 15:34:43.407 (PiMonitor) res (replaced):
2020-06-18 15:34:43.408 Error: (PiMonitor) 'onHeartbeat' failed 'ValueError':'could not convert string to float: '.
2020-06-18 15:34:43.408 Error: (PiMonitor) ----> Line 382 in '/config/plugins/Domoticz-PiMonitor-Plugin-master/plugin.py', function onHeartbeat
2020-06-18 15:34:43.408 Error: (PiMonitor) ----> Line 223 in '/config/plugins/Domoticz-PiMonitor-Plugin-master/plugin.py', function onHeartbeat
2020-06-18 15:34:43.408 Error: (PiMonitor) ----> Line 576 in '/config/plugins/Domoticz-PiMonitor-Plugin-master/plugin.py', function getGPUtemperature
2020-06-18 15:34:43.408 Error: (PiMonitor) ----> Line 496 in '/config/plugins/Domoticz-PiMonitor-Plugin-master/plugin.py', function vcgencmd
