Transfer sensordata from Domoticz to domoticz using dzvents
Posted: Tuesday 16 June 2020 22:22
by hairman63
new here ... i trying to transfer sensordata from my second domoticz device to the first using dzvents scripting.
So far i have a start, but i can't get it up and runing ...
local server = ('http://192.168.xxx.xxx:xxxx')
local callbackString = ('RemoteDataPush_callback')
--devices = {},
timer = {
'every minute',
--variables = {},
--scenes = {},
--groups = {},
--security = {},
httpResponses = {
callbackString,
--customEvents = {},
--system = {},
logging = {
-- level = domoticz.LOG_ERROR, marker = "ERROR Logging ",
-- level = domoticz.LOG_DEBUG, marker = "DEBUG Logging ",
level = domoticz.LOG_INFO, marker = "INFO Logging ",
marker = "Tempz",
execute = function(domoticz, item, info)
local T_Woonk = domoticz.devices('Woonkamer') --94 THP
local T_Kantoor = domoticz.devices('Kantoor') --13 TP
local T_Slaapk = domoticz.devices('Slaapkamer') --95 THP
local T_Keuken = domoticz.devices('Keuken') --96 THP
local T_Slaapk = domoticz.devices('Balkon') --80 TH
local T_Keuken = domoticz.devices('Hal') --98 THP
if (item.isTimer) then
domoticz.openURL({url = server .. '/json.htm?type=command¶m=udevice&idx=' .. 94 ..'&nvalue=0&svalue=' .. T_Woonk.temperature .. ";" .. T_Woonk.humidity .. ";" .. T_Woonk.humidityStatus .. ";" .. T_Woonk.pressure .. ";" .. forecast, callback = callbackString})
elseif (item.isHTTPResponse) then
if (item.json.status == 'OK') then
domoticz.log('Updated the remote device succesfully.')
domoticz.log(item.json)
domoticz.log('Something went wrong updating the remote device', domoticz.LOG_ERROR)
domoticz.log(item.json, domoticz.LOG_ERROR)
domoticz.log('Unknown script trigger.', domoticz.LOG_ERROR)
As you can see i only got it for just one sensor, but taht ain't working either ... dunno what's wrong so far ...
Harry
Re: Transfer sensordata from Domoticz to domoticz using dzvents
Posted: Tuesday 16 June 2020 23:33
by waaren
hairman63 wrote: Tuesday 16 June 2020 22:22
Please check the wiki for the right names of the attributes.
In it's most basic form..
local remoteServer = 'http://192.168.xxx.xxx:xxxx'
local callbackString = 'RemoteDataPush_callback'
return
on =
timer =
'every minute',
httpResponses =
callbackString,
logging =
marker = "Tempz",
execute = function(dz, item)
T_Woonk.remote = 94
if item.isTimer or item.isDevice then
url = remoteServer ..
T_Woonk.remote ..
dz.utils.round(T_Woonk.temperature,2) .. ";" ..
T_Woonk.humidityStatusValue .. ";" ..
T_Woonk.barometer .. ";" ..
T_Woonk.forecast
dz.log(url,dz.LOG_DEBUG)
dz.openURL(
{ url = url,
callback = callbackString,
elseif item.isHTTPResponse then
if item.ok then
dz.log('Updated the remote device succesfully.')
dz.log(item.json)
dz.log('Something went wrong updating the remote device', dz.LOG_ERROR)
dz.log(item, dz.LOG_ERROR)
dz.log('Unknown script trigger.', dz.LOG_ERROR)
Posted: Wednesday 17 June 2020 7:20
by EddyG
Why not use the 'slave' function of Domoticz?
Posted: Wednesday 17 June 2020 7:44
by physiker123
I have the same problem, domoticz cannot transfer the data (I suspect the spaces in the text device...).
The slave function did not work for me, because it only transferred the switches, not the text devices (both rpi with latest beta)
Now I cut the string of the text devices, and transfer every part individually... Not an elegant solution, but it works...
Jens
Posted: Wednesday 17 June 2020 12:24
by hairman63
waaren wrote: Tuesday 16 June 2020 23:33
return
on =
timer =
'every minute',
httpResponses =
callbackString,
logging =
marker = "Tempz",
T_Woonk.remote = 94
T_Woonk.remote ..
T_Woonk.forecast
dz.openURL(
{ url = url,
if item.ok then
dz.log(item.json)
Thanks for your reply ... i will try this tonight ...
Posted: Wednesday 17 June 2020 12:29
by hairman63
EddyG wrote: Wednesday 17 June 2020 7:20
Can you explain how to use 'slave' ..? I'm not familiar with that ...
Posted: Wednesday 17 June 2020 12:39
by EddyG
Ofcource. Setup -> About -> Manual -> page 28
https://www.domoticz.com/wiki/Setting_up_Device_sharing
And several other places, search function does wonders.
Posted: Wednesday 17 June 2020 15:29
by xury
I had problems with master - slave communication between Domoticz instances so I made workaround using MQTT and Node-Red . Example flow with my solution is released on node red flow named Domoticz to Domoticz.
Posted: Wednesday 17 June 2020 19:54
by hairman63
Thanks .... i didn't know ...
Looks very interesting ...
Posted: Wednesday 17 June 2020 21:17
by ronaldbro
I had the same problem. I have master-slave running, but it doesn't work for all devices. Don't know exactly what work and doesn't work, but from my experience the master-slave doesn't work for devices created by python plugins.
I made a dzVents scripts to push the data to an other domoticz, see
https://www.domoticz.com/forum/viewtopi ... 72&t=31618
Hope this helps.
Posted: Wednesday 17 June 2020 21:42
by hairman63
Thanks ... but i got it running with basicaly my first script. My problem wasn't the code after all ... it had something to do with rights on the PC ...
It's now running with this code below ...
local remoteServer = 'http://192.168.xxx.xxx:xx/json.htm?type=command¶m=udevice&idx='
timer = {
'every minute',
httpResponses = {
callbackString,
logging = {
marker = "Tempz",
local T_Balkon = domoticz.devices('Balkon') --80 TH
local T_Hal = domoticz.devices('Hal') --98 THP
local L_Kantoor = domoticz.devices('Licht Kantoor') --12
local L_Keuken = domoticz.devices('Licht Keuken') --97
local IDX_T_Wk = 94
local IDX_T_Kantoor = 13
local IDX_T_Sk = 95
local IDX_T_Keuken = 96
local IDX_T_Balkon = 80
local IDX_T_Hal = 98
local IDX_L_Kantoor = 12
local IDX_L_Keuken = 97
domoticz.openURL({url = remoteServer ..
IDX_T_Wk ..'&nvalue=0&svalue=' ..
T_Woonk.forecast,
IDX_T_Sk ..'&nvalue=0&svalue=' ..
T_Slaapk.temperature .. ";" ..
T_Slaapk.humidity .. ";" ..
T_Slaapk.humidityStatus .. ";" ..
T_Slaapk.barometer .. ";" ..
T_Slaapk.forecast,
callback = callbackString}).afterSec(1)
IDX_T_Keuken ..'&nvalue=0&svalue=' ..
T_Keuken.temperature .. ";" ..
T_Keuken.humidity .. ";" ..
T_Keuken.humidityStatus .. ";" ..
T_Keuken.barometer .. ";" ..
T_Keuken.forecast,
callback = callbackString}).afterSec(2)
IDX_T_Hal ..'&nvalue=0&svalue=' ..
T_Hal.temperature .. ";" ..
T_Hal.humidity .. ";" ..
T_Hal.humidityStatus .. ";" ..
T_Hal.barometer .. ";" ..
T_Hal.forecast,
callback = callbackString}).afterSec(3)
IDX_T_Kantoor ..'&nvalue=0&svalue=' ..
domoticz.utils.round(T_Kantoor.temperature,2) .. ";" ..
T_Kantoor.barometer .. ";" ..
T_Kantoor.forecast,
callback = callbackString}).afterSec(4)
IDX_T_Balkon ..'&nvalue=0&svalue=' ..
T_Balkon.temperature .. ";" ..
T_Balkon.humidity .. ";" ..
T_Balkon.humidityStatus,
callback = callbackString}).afterSec(5)
IDX_L_Kantoor ..'&nvalue=0&svalue=' ..
L_Kantoor.lux,
callback = callbackString}).afterSec(6)
IDX_L_Keuken ..'&nvalue=0&svalue=' ..
L_Keuken.lux,
callback = callbackString}).afterSec(7)
--domoticz.log(item.json)
It works for now ...!
