Dashticz - v3.3.3 Master?
ShaneClark
Post by ShaneClark »
I've just published Dashticz v3.3.3 master.
Main reason is the bugfix for recurring events in the calendar blocks.
I've migrated to a new PHP ical https://trackeasy.fun/usps/ https://showbox.tools/ http://essaywriter.fun/ parser library, which is more up-to-date. This library however requires PHP 7.1 (or higher).
I expect that this will be no issue for most users. If you are still using PHP5, and you can't update to PHP7, then please leave a note here, and I will look for an alternative solution.
The automatic installation scripts uses PHP7 in the Docker image, so that should work without issues.
HansieNL
Re: Dashticz - v3.3.3 Master?
Post by HansieNL »
Can you tell us what your question is?
Blah blah blah
EdwinK
Post by EdwinK »
I believe he's offering help. At least:
Seems so.
HansieNL
Post by HansieNL »
This is a copy of a previous post from Lokonli https://www.domoticz.com/forum/viewtopi ... er#p234400 ???
Blah blah blah
