Anna presets do update but do not trigger an event/log
Posted: Sunday 07 June 2020 11:18
Hello.
Recently I have installed a Plugwise Anna Thermostat and in fact it works well from Domoticz (even with the very new 4.x firmware of the Smile), but there is one thing I don't think is good.
When I select a different preset on the Anna thermostat itself, after a while (with a sensor update) the Preset switch in Domoticz also gets updated but it doesn't trigger an event or a log item in Domoticz. So the switch in Domoticz displays the new state (Home, Away, Night, Vacation) but the event trigger is not happening and in the log this change isn't listed. The other way around, when I select a preset in Domoticz, then it does fire, logs and updates the Anna/Smile, so that way is working correctly.
Is this some kind of bug in the update of the switch, or is it something that has a workaround? I hope that it can be fixed because my events (like the automatic going off of the heating at night) depend on it.
Regards, EJ
Regards, EJ
