Xiaomi Mi door sensor and Window Sensor not working after battery replacement
Posted: Saturday 06 June 2020 17:57
by willie-p
I've replaced my battery of the Xiaomi Mi door sensor and window sensor and it is not working in Domoticz anymore.
In the Xiaomi Home app I see updates of open and closing, etc. but this doesn't reflect in Domoticz.
I've tried to turn on accept new hardware however this doesn't change anything.
Does anyone have an idea to solve this?
Thanks,
Will
Re: Xiaomi Mi door sensor and Window Sensor not working after battery replacement
Posted: Sunday 07 June 2020 9:44
by willie-p
Needless to say, other devices with enough battery still respond well.
This is also the first time in 2 years that I had to replace the battery.
Cheers,
Will
Posted: Wednesday 10 June 2020 15:17
by LouiS22
Think you need to push the pair button, it will refresh the information. What zigbee dongle are you using?
Posted: Thursday 11 June 2020 10:15
by willie-p
Hi Louis22,
Thank you for your response, however this is not how Domoticz has implemented Xiaomi hub.
That is why in app, which connect to the hub I see updates. Via IP address the information is shared with domoticz.
Posted: Saturday 13 June 2020 11:15
by LouiS22
willie-p wrote: Thursday 11 June 2020 10:15
Hi Louis22,
Ah, so you use it with the hub. I never used xiaomi's hub but opted to a zigbee dongle. Much better as I dont rely on Xiaomi's cloud (mostly privacy issues).
Posted: Monday 22 June 2020 17:27
by willie-p
The issue is solved.
The only change I made is re-enter the password in the "Hardware" menu and update the device.
For those who are new to this, with version 2, you leave the username empty.
I don't use the Xiaomi cloud, my firewall blocks any connection. I use only the internal IP.
Kind regards,
Will
