Calendar new view
Brinkie
Domoticz version: 2020.1
Calendar new view
Post by Brinkie »
A new suggestion for the calendar component. Where the list of calendar items are represented (see also the example calendar)
  • grouped by day
  • start and endtime
  • each calendar item has a color bar (corresponding the imported calandar)
  • Subscription of the calendar item
This list of the calendar is more like the iphone calendar and could be used as a family calendar too (Combined calendars).
clinkadink
Re: Calendar new view
Post by clinkadink »
Are you using the beta version? If so, the calendar block already allows for family calendars. You can add multiple .ics urls to the same block and they are displayed (color coded) in the same calendar. There are 3 layout options; 0, 1 and 2. Options 0 and 1 follow the same "agenda" format as above. But option 1 is 'grouped by day'. Whereas the latter being the traditional tabular calendar.
Layout 0
Layout 1
Layout 2
More info here: https://www.domoticz.com/forum/viewtopi ... 67&t=32132
Brinkie
Post by Brinkie »
Thanks for your reply! I'm using the latest beta version of Dashticz, but miss some functionality. It's more UX design related.
See attachment for more details.
New format calendar.png (112.01 KiB) Viewed 6284 times
