LUA - device counter - updatedevice cumulate value
Posted: Thursday 04 June 2020 11:21
by multinet
Hello
I've a scripts that count the number of minutes à pump is powered on. It was running fine since few years.
I've just updated to domoticz v2020.2
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: 3.7.3 (default, Dec 20 2019, 18:57:59) [GCC 8.3.0]
My lua script is now running differently it seems that every "UpdateDev" call it cumulate the values instead of change it
my function:
function UpdateDev(device,nvalue,svalues)
    --Met à jour un device numérique Domoticz
    print("Updatedev")
    print("nvalue:"..tostring(nvalue))
    print("svalues:"..tostring(svalues))
    commandArray[CmdIdx] = {['UpdateDevice'] = otherdevices_idx[device]..'|'..tostring(nvalue)..'|'..tostring(svalues)}
    CmdIdx=CmdIdx+1
result before / after update domoticz (i updated domoticz on june 1st):
Capture d’écran 2020-06-04 à 11.16.39.png (180.23 KiB) Viewed 949 times
and my device :
Capture d’écran 2020-06-04 à 11.20.47.png (16.32 KiB) Viewed 949 times
exemple of log call 1
2020-06-04 11:32:02.469  Status: LUA: ---Temperature de la piscine : 27.0
2020-06-04 11:32:02.618  Status: LUA: Déjà effectué : 680.0 minutes sur 815
2020-06-04 11:32:02.620  Status: LUA: PpeRest (conso piscine) : 135.0
2020-06-04 11:32:02.621  Status: LUA: =PpeDuree (conso piscine) : 815
2020-06-04 11:32:02.622  Status: LUA: -PpeFait (conso piscine) : 680.0
2020-06-04 11:32:02.624  Status: LUA: Temps restant de filtration : 135.0 minutes
2020-06-04 11:32:02.625  Status: LUA: Updatedev
2020-06-04 11:32:02.626  Status: LUA: nvalue:0
2020-06-04 11:32:02.628  Status: LUA: svalues:680.0
call 2:
020-06-04 11:33:03.137  Status: LUA: ---Temperature de la piscine : 27.0
2020-06-04 11:33:03.249  Status: LUA: Déjà effectué : 680.0 minutes sur 815
2020-06-04 11:33:03.251  Status: LUA: PpeRest (conso piscine) : 135.0
2020-06-04 11:33:03.252  Status: LUA: =PpeDuree (conso piscine) : 815
2020-06-04 11:33:03.253  Status: LUA: -PpeFait (conso piscine) : 680.0
2020-06-04 11:33:03.254  Status: LUA: Temps restant de filtration : 135.0 minutes
2020-06-04 11:33:03.256  Status: LUA: Updatedev
2020-06-04 11:33:03.257  Status: LUA: nvalue:0
2020-06-04 11:33:03.258  Status: LUA: svalues:680.0
What is going wrong ?
Thank a lot and take care.
Multinet
Re: LUA - device counter - updatedevice cumulate value
Posted: Thursday 04 June 2020 11:53
by waaren
multinet wrote: Thursday 04 June 2020 11:21 I've a scripts that count the number of minutes à pump is powered on. It was running fine since few years.
Check this topic for a possible explanation
Posted: Thursday 04 June 2020 12:07
by multinet
Hello Waaren
Thank you very much for you quick answer.
It seems that i'm concerned by what you write on the other post : I use an incremental counter and domoticz change the behavior of it in my new version).
Nos i have to adaot my. lua script !
Thank you
Multinet
