Why does this dzVents script not work  [Solved]
RvdM
Domoticz version: 2020.2 1
Post by RvdM »
After migrating to the newest version of Domoticz my climatControl scripts (written in dzVents) stopped working.
Based on the temperature and humidity in our home certain user variables are regularly set.
Based on several time scripts the mechanical fan should switch to a lower or higher RPM (DIMMER 0-10V Z-WAVE)
Tried to get this working again but somehow I can't. Even the log line doesn't work.
        active = true,
                ['timer'] = {'at 19:28'}
    	logging = {
            level = domoticz.LOG_DEBUG,
        execute = function(dz)
            fan = dz.devices('Mechanische Ventilatie')
            target = domoticz.variables('climatControlBaselinePostCooking').value
            domoticz.log('Mechanische ventilatie snelheid wordt aangepast (Post-Cooking) - Level: ' .. target )
            fan.switchSelector(target)
Logging:
2020-06-01 19:28:00.086 Status: dzVents: Info: ------ Start internal script: climatControlPostCooking:, trigger: "at 19:28"
2020-06-01 19:28:00.090 Status: dzVents: Debug: Processing device-adapter for Mechanische Ventilatie: Switch device adapter
2020-06-01 19:28:00.090 Status: dzVents: Info: ------ Finished climatControlPostCooking
Running virtualized domoticz server on a proxmox cluster with a slave for optimal RFX communication. Using Aeotec Z-Stick Gen5, rfxtrx433e, Homebridge and a Philips HUE bridge for all sort of home automation.
besix
Re: Why does this dzVents script not work
Post by besix »
I don't know dzVents, but it can help
        active = true,
    	logging = {
            target = dz.variables('climatControlBaselinePostCooking').value
            dz.log('Mechanische ventilatie snelheid wordt aangepast (Post-Cooking) - Level: ' .. target )
RvdM wrote: Monday 01 June 2020 19:31 Tried to get this working again but somehow I can't. Even the log line doesn't work.
You cannot mix dz (first parm of the execute function) and domoticz in the body of the script. Either they are both dz or both domoticz.
What are the possible values of the variable climatControlBaselinePostCooking ?
RvdM
Post by RvdM »
waaren wrote: Monday 01 June 2020 20:06
Ah yes. With that the printing works. However still not the adjustment of the fan.
User variable is a integer.
        active = true,
                ['timer'] = {'at 21:14'}
    	logging = {
besix
Post by besix »
But for the selector
must be 0ff, 10, 20 ..... 60
RvdM
Post by RvdM »
Shouldnt that be fine with an integer?
besix
Post by besix »
Code example for selector
if (dz.devices('Kominek').state == 'On' and dz.variables('kominek').value == 0) then
		    dz.devices('Kominek Wentylator').switchOn()
			dz.devices('Kominek przepustnica').switchSelector(60)
			dz.log('Rozpalanie')
The position of the selector 60 is the name of the level.
Level 1 is Off, 2 is 10, 3 is 20 etc.
RvdM wrote: Monday 01 June 2020 21:48 Shouldnt that be fine with an integer?
Yes, it should. Can you show whats in the log ?
besix wrote: Monday 01 June 2020 21:52 The position of the selector 60 is the name of the level.
Sorry but no.
60 is the level in this example. The name can be any string.
RvdM
Post by RvdM »
waaren wrote: Monday 01 June 2020 22:21
2020-06-01 22:29:00.464 Status: dzVents: Info: ------ Start internal script: climatControlPostCooking:, trigger: "at 22:29"
2020-06-01 22:29:00.468 Status: dzVents: Debug: Processing device-adapter for Mechanische Ventilatie: Switch device adapter
2020-06-01 22:29:00.468 Status: dzVents: Info: Mechanische ventilatie snelheid wordt aangepast (Post-Cooking) - Level: 50
2020-06-01 22:29:00.468 Status: dzVents: Info: ------ Finished climatControlPostCooking
RvdM wrote: Monday 01 June 2020 22:42 [
I assume based on this that the device is not set at level 50 ?
Can you show a printscreen of the levels of the device?
What is the type / subtype (as seen on the device tab?
RvdM
Post by RvdM »
See attached, and no its not set to 50
Schermafbeelding 2020-06-01 om 22.52.38.png (140.41 KiB) Viewed 2384 times
Schermafbeelding 2020-06-01 om 22.52.29.png (399.51 KiB) Viewed 2384 times
besix
Re: Why does this dzVents script not work  [Solved]
Post by besix »
selector please no dimmer
or
        active = true,
    	logging = {
            fan.dimTo(target)
RvdM wrote: Monday 01 June 2020 22:53 See attached, and no its not set to 50
switchSelector is to be used for selector type devices. For dimmers you should use the dimTo() method
RvdM
Post by RvdM »
That indeed was the probleem. No sure why it worked in older versions of Domoticz because this script was from a post 2020 release
RvdM
Post by RvdM »
Just started up the old machine and the code looks like this
        active = true,
                ['timer'] = {'at 18:30'}
        execute = function(domoticz)
                domoticz.log('Ventilatie op post-kookstand')
                domoticz.devices('Mechanische Ventilatie').switchSelector(domoticz.variables('climatControlBaselinePostCooking').value)
RvdM wrote: Monday 01 June 2020 23:23 Just started up the old machine.
Could well be that this switchSelector() method worked in your old version. It was never intended to work on a dimmer device and since the change in the switchSelector code in dzVents 2.4.22 it no longer work for dimmers.
