after update to 12106 OZW devices start being sensible for first time after switch to OZW 1.6 of Domoticz
Posted: Sunday 31 May 2020 10:37
I just want to say thank you for making an update (somewhere between 2020.2.12086 and 2020.2.12106) which for the first time since the Beta Domoticz release introduced OZW 1.6 is showing/detecting my z-wave devices sensibly.
Before this update (and after the switch to OZW 1.6) devices would be detected with non-sense data:
For example i have 3 "FIBARO System FGWPE/F Wall Plug Gen5" but often these would include things like LUX or CO2 values or simply only have a on/off value and nothing else (no power measurements).
I also have a "FIBARO System FGS223 Double Relay" which contains two relays but often only one would showup after a reboot (or node refresh), also even this sometimes had some non-sense values like wind-direction or rainfall measurement.
Even the sensor device i have "AEON Labs ZW100 MultiSensor 6" would report non-sense values like Formaldehyde CH20 Level (although not that often).
The only other z-wave device i have is "AEON Labs ZW090 Z-Stick Gen5 EU".
Obviously the OZW integration in Domoticz has been an issue (my Z-wave network does not even include devices that can sense CH20 or CO2) but it seems now a step in the right direction is taken, thanks!
