[Solved] DzVents scripts not working anymore after upgrade
Posted: Saturday 30 May 2020 19:31
by McJohn
The 2 different scripts below worked perfectly in
Raspbian Stretch 9.8
Domoticz 4.9700
But after an upgrade / new installation to:
Raspbian Buster 10
Domoticz 2020.2 (build 12067)
Both scripts are dead.
Can somebody help us with the solution?
Thanks in advance.
Power available Script:
            timer = { 'every minute' }},
    execute = function( dz )
        local voltage = dz.devices('Voltage')
        local power= dz.variables('Power')
        local function setvar(var, to)
            if var.value ~= to and dz.startTime.secondsAgo > 120 then var.set(to) end
        if voltage.lastUpdate.secondsAgo > 120 then
            setvar(power,'Off')
            setvar(power,'On')
Max temperature to Text Device script:
local temperatureDevice = 'Temp+HumOutside -- change to name of your Temperature device
local temperatureTextDevice = 'TempOutside Max' -- change to name of your text device
local temperatureVariable = 'TempOutsideMax' -- change to name of your variable
                     devices = { temperatureDevice },
                     timer = { 'at 00:03' },         -- time to reset variable and text device
    execute = function(dz, item)
        temperatureVariable =  dz.variables(temperatureVariable)
        temperatureTextDevice = dz.devices(temperatureTextDevice)
        if item.isTimer then
            temperatureVariable.set(-55)
            temperatureTextDevice.updateText('max temp today: notset yet' .. dz.time.rawTime)
        elseif item.temperature > temperatureVariable.value then
            temperatureVariable.set(dz.utils.round(item.temperature,1))
            temperatureTextDevice.updateText('max temp today: ' .. dz.utils.round(item.temperature,1) .. '° C om ' .. dz.time.rawTime)
Re: DzVents scripts not working anymore after upgrade
Posted: Saturday 30 May 2020 19:45
by freijn
I had a calculation going wrong.
There must be some hint in the log file. I suspect the round function
Posted: Saturday 30 May 2020 20:13
by waaren
McJohn wrote: Saturday 30 May 2020 19:31 Can somebody help us with the solution?
I don't see something in the scripts that would cause them to fail.
Do you see anything in the log?
Do these scripts start at all; are there any other dzVents scripts active and working?
If you don't seen anything please double check if event system and dzVents are both set to active.
I activate debug logging in below scripts. Can you try again with these?
return
    on =
       timer =
          'every minute',
   logging =
       level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when everything executes without problems
            setvar(power,'Off')
            setvar(power,'On')
return
    on =
        devices =
            temperatureDevice,
        timer =
           'at 00:03',
   logging =
Posted: Saturday 30 May 2020 20:17
by waaren
freijn wrote: Saturday 30 May 2020 19:45 I had a calculation going wrong.
The round function failed in some versions when it was feeded with a type string but here it is a number (the temperature attribute is of type number)
Re: DzVents scripts not working anymore after upgrade  [Solved]
Posted: Saturday 30 May 2020 21:18
by McJohn
Thank you so much for the fast reply and the hint of the day:
That did the trick!
After a fresh install of Domoticz version Domoticz 2020.2 (build 12067) dzVents is default disabled....
Don't ask me why...
After enabling, all the scripts are working perfect again.
Thanks for your time. :D
