Change heights of certain blocks Topic is solved
madradrakie
Post by madradrakie »
I would like to change the height of a couple (or most of the blocks) but not all. I already used the following code but then all the blocks are changed in height, also the top bar and the graphs.
div[class*='block_'] {
  height: 70px !important;
As a work around i now used the following code but then my styling css file becomes very large
.block_76_1 {
.block_76_2 {
.block_76_5 {
is there another workaround?
Lokonli
Re: Change heights of certain blocks
Post by Lokonli »
All Domoticz blocks also have the css class .mh attached to them, so I guess you can add to custom.css:
.mh {
Alternatively, you could use the addClass block parameter to add a custom class to specific blocks:
block[123] = {
   addClass:'height70'
and in custom.css:
.height70 {
madradrakie
super! the addclass function works perfectly! :D
