Zero (0) values in graph
Posted: Thursday 28 May 2020 14:53
I'm using the ToonAPILib to get power consumption etc from Toon (Netherlands). It is working fine some years now.
The problem i'm having is that the graph shows 0 values in the graph. So the line drops (each 35minutes or so). See picture:
If i'm looking in the logging it show no values like that:
Only thing what I see is that the graph gives graph info about values (when you hover above graph) on each 5 minutes (e.g. 10.05, 10.10, 10.15...) and the timestamps in logging are about 6 minutes from each other. Don't know if that is the problem because other graphs from other devices don't have this.
Hope someone knows how to fix this...
2020-05-28 13:41:56.444 (Toon) Update power/solar usage: 742783;704131;59768;132476;364;0
2020-05-28 13:47:56.569 (Toon) Update power/solar usage: 742783;704156;59768;132581;370;0
2020-05-28 13:53:57.161 (Toon) Update power/solar usage: 742783;704180;59768;132584;0;0
2020-05-28 13:58:57.512 (Toon) Update power/solar usage: 742783;704180;59768;132704;0;0
2020-05-28 14:04:57.696 (Toon) Update power/solar usage: 742783;704211;59768;132758;380;0
2020-05-28 14:10:57.648 (Toon) Update power/solar usage: 742783;704216;59768;133025;0;0
2020-05-28 14:16:57.766 (Toon) Update power/solar usage: 742783;704250;59768;133111;476;0
2020-05-28 14:22:57.865 (Toon) Update power/solar usage: 742783;704280;59768;133127;0;0
2020-05-28 14:28:57.897 (Toon) Update power/solar usage: 742783;704280;59768;133282;0;0
2020-05-28 14:34:58.089 (Toon) Update power/solar usage: 742783;704280;59768;133542;0;0
2020-05-28 14:40:58.244 (Toon) Update power/solar usage: 742783;704280;59768;133764;0;0
...Hope someone knows how to fix this...
