Blinds - "Stop" Button send the STOP command twice to Domoticz Topic is solved
Ashitaka
Post by Ashitaka »
Well hello there,
I witnessed a strange behavior while testing my blinds on Dashticz.
Inside, Domoticz, no problems at all, everything is working as intended.
Meanwhile, when I'm using the blind inside Dashticz, the "STOP" button isn't working as intended.
When using it, it sent twice the json request to Domoticz API instead of once.
var blind_room1               = 12;
blocks[blind_room1] = {}
blocks[blind_room1]['title'] = 'Blind of Room1';
blocks[blind_room1]['width'] = 6;
blocks[blind_room1]['last_update'] = false;
I could'nt figure where the bug were located inside the code (not the one I quoted obviously ^^').
The problem is:
When my blind is receiving the first request, it stopped, but when the second request occured, he started again to move xD, so I can't use the stop button properly, because it's not stopping xD
(I'm using the beta btw)
Lokonli
Re: Blinds - "Stop" Button send the STOP command twice to Domoticz
Post by Lokonli »
I'll check
Lokonli
Post by Lokonli »
Fixed in latest beta.
Ashitaka
Post by Ashitaka »
Thanks a lot, I'll test that soon (is it already in the 3.4.9.1 ?)
Lokonli
Post by Lokonli »
You have to pull the latest version from github. I did not increase the version number yet.
Ashitaka
Post by Ashitaka »
It's working ! Thanks for the fix
