new command with .afterSec or cancel with .cancelQueuedCommands()
Posted: Wednesday 27 May 2020 14:21
i have a script which uses the afterSec(20) option.
at the moment when the script is called the timer is reset to 20 seconds again.
is this the way to do things or should i first cancel the previous command with .cancelQueuedCommands()
eg, is the .cancelQueuedCommands() neccesary because it works with this command as well but i do not know if this eats up memory by extending the timer instead of closing it and calling it again
i basically want the timer to be extended when movement is detected instead of switching the light off and on again
active = true,
devices = {
['PIR sensor'] = {'between sunset and 00:00'}
execute = function(domoticz, beweging)
domoticz.devices('Veranda').cancelQueuedCommands()
if beweging.state == 'On' then
domoticz.devices('Veranda').switchOn().checkFirst().afterSec(20)
