HDD not enough memory?
Posted: Monday 25 May 2020 14:40
by Opus
I have set up booting from HDD.
However, everything ended up in the /dev/root directory and only uses 1.8Gb of 320Gb. Booting works fine.
I see with fdisk:
dev/sda1 256M
dev/sda2 with 297G
How can I get everything into the big partition?
Micha
Re: HDD not enough memory?
Posted: Sunday 31 May 2020 18:54
by foxmulder06
This is not related to DOMOTICZ but to your Linux OS.
Depending on the OS, you should read the documentation to reorganize your hard disk/Partitions differently and may be, think to reinstall it properly.
Pascal
Posted: Sunday 31 May 2020 19:15
by sancla
Assuming that you installed Raspbian for this, you could follow these instructions:
https://raspberry-projects.com/pi/softw ... ls/gparted
Let us know how that works out for you and if you need any more help with that...
