suddenly getting dzvents errors
Posted: Monday 25 May 2020 11:50
i am currently using build 2020.1.11839 on a synoloy DS718+
This version is running stable for months now.
suddenly i got these errors in the log which were caused at 00:00
i did not change anything and the script dzV-Tuinsproeier does exist in /usr/local/domoticz/var/scripts/dzVents/generated_scripts/
what could have caused this behaviour?
the errors also stopped on their own
2020-05-25 00:00:00.527 Error: dzVents: Error: (3.0.1) module 'dzV-Tuinsproeier' not found:
2020-05-25 00:00:00.527 no field package.preload['dzV-Tuinsproeier']
2020-05-25 00:00:00.527 no file '/usr/local/domoticz/var/scripts/dzVents/dzV-Tuinsproeier.lua'
2020-05-25 00:00:00.527 no file '/usr/local/domoticz/dzVents/runtime/dzV-Tuinsproeier.lua'
2020-05-25 00:00:00.527 no file '/usr/local/domoticz/dzVents/runtime/device-adapters/dzV-Tuinsproeier.lua'
2020-05-25 00:00:00.527 no file '/usr/local/domoticz/var/scripts/dzVents/dzVents/dzV-Tuinsproeier.lua'
2020-05-25 00:00:00.527 no file '/usr/local/domoticz/var/scripts/dzVents/scripts/dzV-Tuinsproeier.lua'
2020-05-25 00:00:00.527 no file '/usr/local/domoticz/var/scripts/dzVents/../lua/dzV-Tuinsproeier.lua'
2020-05-25 00:00:00.527 no file '/usr/local/domoticz/var/scripts/dzVents/scripts/modules/dzV-Tuinsproeier.lua'
2020-05-25 00:00:00.527 no file '/usr/local/domoticz/var/scripts/dzVents/generated_scripts/dzV-Tuinsproeier.lua'
2020-05-25 00:00:00.527 no file '/usr/local/domoticz/var/scripts/dzVents/data/dzV-Tuinsproeier.lua'
2020-05-25 00:00:00.527 no file '/usr/local/domoticz/var/scripts/dzVents/modules/dzV-Tuinsproeier.lua'
2020-05-25 00:00:00.527 no file '/usr/local/share/lua/5.3/dzV-Tuinsproeier.lua'
2020-05-25 00:00:00.527 no file '/usr/local/share/lua/5.3/dzV-Tuinsproeier/init.lua'
2020-05-25 00:00:00.527 no file '/usr/local/lib/lua/5.3/dzV-Tuinsproeier.lua'
2020-05-25 00:00:00.527 no file '/usr/local/lib/lua/5.3/dzV-Tuinsproeier/init.lua'
2020-05-25 00:00:00.527 no file './dzV-Tuinsproeier.lua'
2020-05-25 00:00:00.527 no file './dzV-Tuinsproeier/init.lua'
2020-05-25 00:00:00.527 no file '/usr/local/lib/lua/5.3/dzV-Tuinsproeier.so'
2020-05-25 00:00:00.527 no file '/usr/local/lib/lua/5.3/loadall.so'
2020-05-25 00:00:00.527 no file './dzV-Tuinsproeier.so'
