P1 Sensor data
Posted: Monday 25 May 2020 11:41
by LjMouzer
Hi All,
I'm new to domoticz.
Im using a synology nas with domoticz to read out P1 smart meter data.
Now i would like to send that data to a tcp/ip client in crestron.
I allready managed to set up communication between crestron & domoticz. Now i need to find a way to filter the response data from domoticz
Currently the repply from http://192.168.1.21:8084/json.htm?type= ... favorite=1 is too long
Because my crestron tcp/ip client has a limit of 255 characters i would like to filter the json repply to use the "data" only.
How can i modify this response within a HTTP get url ?
- Spoiler: show
{ "ActTime" : 1590399357, "AstrTwilightEnd" : "00:00", "AstrTwilightStart" : "00:00", "CivTwilightEnd" : "22:27", "CivTwilightStart" : "04:50", "DayLength" : "16:08", "NautTwilightEnd" : "23:32", "NautTwilightStart" : "03:45", "ServerTime" : "2020-05-25 11:35:57", "SunAtSouth" : "13:38", "Sunrise" : "05:34", "Sunset" : "21:43", "app_version" : "2020.1", "result" : [ { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "Counter" : "2944.124", "CounterDeliv" : "150.706", "CounterDelivToday" : "0.209 kWh", "CounterToday" : "5.359 kWh", "CustomImage" : 0, "Data" : "1541521;1402603;51219;99487;30;0", "Description" : "", "Favorite" : 1, "HardwareID" : 2, "HardwareName" : "Slimme meter", "HardwareType" : "P1 Smart Meter USB", "HardwareTypeVal" : 4, "HaveTimeout" : false, "ID" : "0001", "LastUpdate" : "2020-05-25 11:35:57", "Name" : "Power", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "Energy", "SwitchTypeVal" : 0, "Timers" : "false", "Type" : "P1 Smart Meter", "TypeImg" : "counter", "Unit" : 1, "Usage" : "30 Watt", "UsageDeliv" : "0 Watt", "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "1" }, { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 0, "Data" : "239.5 V", "Description" : "", "Favorite" : 1, "HardwareID" : 2, "HardwareName" : "Slimme meter", "HardwareType" : "P1 Smart Meter USB", "HardwareTypeVal" : 4, "HaveTimeout" : false, "ID" : "00000001", "LastUpdate" : "2020-05-25 11:35:57", "Name" : "Voltage L1", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "Voltage", "Timers" : "false", "Type" : "General", "TypeImg" : "current", "Unit" : 1, "Used" : 1, "Voltage" : 239.5, "XOffset" : "0", "YOffset" : "0", "idx" : "2" }, { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 0, "Data" : "239.2 V", "Description" : "", "Favorite" : 1, "HardwareID" : 2, "HardwareName" : "Slimme meter", "HardwareType" : "P1 Smart Meter USB", "HardwareTypeVal" : 4, "HaveTimeout" : false, "ID" : "00000002", "LastUpdate" : "2020-05-25 11:35:57", "Name" : "Voltage L2", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "Voltage", "Timers" : "false", "Type" : "General", "TypeImg" : "current", "Unit" : 1, "Used" : 1, "Voltage" : 239.19999999999999, "XOffset" : "0", "YOffset" : "0", "idx" : "3" }, { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 0, "Data" : "376 Watt", "Description" : "", "Favorite" : 1, "HardwareID" : 2, "HardwareName" : "Slimme meter", "HardwareType" : "P1 Smart Meter USB", "HardwareTypeVal" : 4, "HaveTimeout" : false, "ID" : "0000000", "LastUpdate" : "2020-05-25 11:35:57", "Name" : "Usage L1", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "Electric", "Timers" : "false", "Type" : "Usage", "TypeImg" : "current", "Unit" : 1, "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "5" }, { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 0, "Data" : "239 V", "Description" : "", "Favorite" : 1, "HardwareID" : 2, "HardwareName" : "Slimme meter", "HardwareType" : "P1 Smart Meter USB", "HardwareTypeVal" : 4, "HaveTimeout" : false, "ID" : "00000003", "LastUpdate" : "2020-05-25 11:35:57", "Name" : "Voltage L3", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "Voltage", "Timers" : "false", "Type" : "General", "TypeImg" : "current", "Unit" : 1, "Used" : 1, "Voltage" : 239.0, "XOffset" : "0", "YOffset" : "0", "idx" : "4" }, { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 0, "Data" : "35 Watt", "Description" : "", "Favorite" : 1, "HardwareID" : 2, "HardwareName" : "Slimme meter", "HardwareType" : "P1 Smart Meter USB", "HardwareTypeVal" : 4, "HaveTimeout" : false, "ID" : "0000000", "LastUpdate" : "2020-05-25 11:35:57", "Name" : "Usage L2", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "Electric", "Timers" : "false", "Type" : "Usage", "TypeImg" : "current", "Unit" : 2, "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "6" }, { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 0, "Data" : "0 Watt", "Description" : "", "Favorite" : 1, "HardwareID" : 2, "HardwareName" : "Slimme meter", "HardwareType" : "P1 Smart Meter USB", "HardwareTypeVal" : 4, "HaveTimeout" : false, "ID" : "0000000", "LastUpdate" : "2020-05-25 11:35:56", "Name" : "Usage L3", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "Electric", "Timers" : "false", "Type" : "Usage", "TypeImg" : "current", "Unit" : 3, "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "7" }, { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "Counter" : "557.757", "CounterToday" : "0.045 m3", "CustomImage" : 0, "Data" : "557.757", "Description" : "", "Favorite" : 1, "HardwareID" : 2, "HardwareName" : "Slimme meter", "HardwareType" : "P1 Smart Meter USB", "HardwareTypeVal" : 4, "HaveTimeout" : false, "ID" : "0001", "LastUpdate" : "2020-05-25 11:35:11", "Name" : "Gas", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "Gas", "SwitchTypeVal" : 1, "Timers" : "false", "Type" : "P1 Smart Meter", "TypeImg" : "counter", "Unit" : 2, "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "11" }, { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 0, "Data" : "387 Watt", "Description" : "", "Favorite" : 1, "HardwareID" : 2, "HardwareName" : "Slimme meter", "HardwareType" : "P1 Smart Meter USB", "HardwareTypeVal" : 4, "HaveTimeout" : false, "ID" : "0000000", "LastUpdate" : "2020-05-25 11:35:56", "Name" : "Delivery L3", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "Electric", "Timers" : "false", "Type" : "Usage", "TypeImg" : "current", "Unit" : 6, "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "10" } ], "status" : "OK", "title" : "Devices" }
