Nefit Easy connection on Windows 10
Posted: Sunday 24 May 2020 20:35
by xyntec
Hi, after another crash on my pi, I decided to switch to a small windows pc and run my domoticz installation from there. So far everything worked a lot quicker and way more user friendly then all the sudo this sudo that. The only thing that I still would like to get working is the connection to my nefit easy. But so far I have only been able to find the setup on a PI, anyone knows (or can direct me to an existing post?) if this is possible and how to do this? I added the hardware in domoticz, but I just don't know now how to run the server and where to put the file with the login data in windows (which is only explained for PI as far as I found.
Re: Nefit Easy connection on Windows 10
Posted: Monday 25 May 2020 14:51
by FireWizard
If you don't want or if you are not able to use the Nefit Easy directly to Domoticz, you can use it also via Node Red and MQTT.
See: https://flows.nodered.org/node/node-red ... efit-easy2
Howto install Mosquitto on Windows: http://www.steves-internet-guide.com/in ... to-broker/
Howto install Node Red on Windows: https://nodered.org/docs/getting-started/windows
Posted: Monday 25 May 2020 18:47
by xyntec
Thanks! It works now :-)
uh, I thought it worked at least...all the data showed up in domoticz, but when I tried to change the mode or set the temperature, nothing happened.
After that the data in domoticz also didn't update anymore, I actually saw the network get lost for a few seconds on the Easy.
In the log I see error setting user mode, then error setting setpoint, and after that continuous error getting http data, and also 1 time error CheckAuthToken - session ID not found.
Any ideas?
Posted: Monday 25 May 2020 21:33
by FireWizard
HI,
@xyntec
Unfortunately I do not own a Nefit Easy and I have never used this solution before.
I knew about the existence, as I own a Nefit boiler and has bee looking for it.
But I can try to take a look.
Can you publish your flow (without the private data)
Posted: Monday 25 May 2020 22:03
by xyntec
I have no flow, I just only see the data. It worked when I started the server and connected to it, when I tried to change the mode and setpoint it lost connection and never came back. That is in domoticz, because when I ask for status in windows it just shows fine and also updates.
Posted: Monday 25 May 2020 22:09
by xyntec
inside domoticz I used to have a flow that switched off heating when my alarm went in away mode, but that flow is not active yet. I just want to be able to see my temperature, and change the mode and preset temperature.
Posted: Monday 25 May 2020 22:40
by FireWizard
I don't think, you should set a data time-out. Just disable.
Not necessary, before it works perfect.
I suggest you look at this forum thread:
https://www.domoticz.com/forum/viewtopi ... nefit+easy
I do not own a Nefit Easy, nor use this "hardware" or even Windows.
Posted: Tuesday 26 May 2020 7:32
by xyntec
I initially didn't have a timeout set, but I just tried to see if this helped. But I will browse the mentioned post some more.
I just don't understand that it worked (as far as reading data) until I tried to write something and thereafter nothing seems to work anymore.
It seems to be in domoticz since directly checking state inside windows works fine.
Posted: Tuesday 26 May 2020 18:42
by xyntec
I think the problem is that it doesn't know the password when setting, normally in pi I use the export commands, and after that all commands work without having to enter the password again. But I have no idea how to do this in node JS. All commands directly from within windows work just fine.
