Fibaro Dimmer 2 (FGD-212)
Posted: Saturday 23 May 2020 22:57
by Eibersite
Domoticz 2020.2
I'm using a Fibaro Dimmer 2 (FGD-212) with a Mono-stable input (button)/Momentary Switch and so far I am very satisfied with the dimmer.
In Domoticz there is a Instance 2.
Can someone explain to me what is for, switching it gives no result?
Instance 2.JPG (21.34 KiB) Viewed 631 times
And can someone explain to me how to use S2.
Switching S2 with a Mono-stable input (button)/Momentary Switch doesn't seem to do anything at all.
Re: Fibaro Dimmer 2 (FGD-212)
Posted: Friday 29 May 2020 14:44
by cos4x4
this is what i found in the manual.
The Dimmer 2 provides the association of five groups:
1st Association Group „Lifeline” reports state of the device. Main
Z-Wave+ network controller should be added to this group. The „Lifeline”
group can handle only one device. It is not recommended to
modify this group.
2nd Association Group „On/Off (S1)” is assigned to switch no. 1.
Sends BASIC command class frame according to the state of the device.
3rd Association Group „Dimmer (S1)” is assigned to switch no. 1.
Sends MULTILEVEL SWITCH command class frame. Allows sending
dim/brighten command to associated devices.
4th Association Group „On/Off (S2)” is assigned to switch no. 2.
5th Association Group „Dimmer (S2)” is assigned to switch no. 2.
