First thing I found that it is (no longer?) possible to create an account on the wiki page to make edits to pages. I found the following that could use some updates:
- FAQ 'button' on home page of the wiki doesn't go to a webpage but instead downloads a file named 'FAQ'
- On the Let's encrypt page https://www.domoticz.com/wiki/Native_se ... ts_Encrypt there is a section about renewing the certificate. However, the command noted is incorrect/unclear for the novice user. For example, certbot-auto is by default not available from commandline, you need to point to /etc/letsencrypt/certbot-auto. Also, it refers to a script called deploy-cert.sh, which doesn't exist. The script referred to is probable about moving the files from the letsencrypt folder, an example should be provided.
Kind regards
Wiki account and updates
- waaren
Re: Wiki account and updates
Just send me a PM with your preferred username and Email address and I will create your account.IceBlackz wrote: Saturday 23 May 2020 14:01 First thing I found that it is (no longer?) possible to create an account on the wiki page to make edits to pages.
Sorry for any inconvenience but this way of working is necessary because of the massive spam attacks.
