Unable to Install on pi4
Posted: Monday 18 May 2020 9:22
by pr0phet
Hi there. Ive got a trouble with install.
Raspbian buster pi4 as per wiki instruction.
- Spoiler: show
- ::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
::: Checking for apt-utils... installed!
::: Checking for whiptail... installed!
::: Checking for git... installed!
::: Checking for curl... installed!
::: Checking for unzip... installed!
::: Checking for wget... installed!
::: Checking for sudo... installed!
::: Checking for cron... installed!
::: Checking for libudev-dev... installed!
::: Checking for libcurl4... installed!
::: Checking for libusb-0.1... installed!
::: Downloading Domoticz
::: Current User: pi
HTTP Port: 80
HTTPS Port: 443
::: Destination folder=/home/pi/domoticz
::: Creating /home/pi/domoticz
--2020-05-18 08:11:33-- http://www.domoticz.com/download.php?ch ... ine=armv7l
Resolving www.domoticz.com (www.domoticz.com)... 104.31.79.142, 104.31.78.142, 2606:4700:3036::681f:4e8e, ...
Connecting to www.domoticz.com (www.domoticz.com)|104.31.79.142|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://www.domoticz.com/download.php?c ... ine=armv7l [following]
--2020-05-18 08:11:33-- https://www.domoticz.com/download.php?c ... ine=armv7l
Connecting to www.domoticz.com (www.domoticz.com)|104.31.79.142|:443... connected.
GnuTLS: Error in the pull function.
Unable to establish SSL connection.
How to resolve that?
Sistem is up to date with all instructions.
Re: Unable to Install on pi4
Posted: Monday 18 May 2020 9:27
by sancla
Hi there,
Can you tell me what the command is that u used to start the installation?
Second, if it helps, you can also follow this guide to assist your with the installation:
https://sancla.com/domoticz/raspberry-p ... -domoticz/
Posted: Monday 18 May 2020 9:32
by waaren
pr0phet wrote: Monday 18 May 2020 9:22
Can you try again? Maybe the system was too busy. I tested the download just now and it does work from my system.
domoticz.com seems to be under ddos attacks quite frequently and that could have caused your issue.
Posted: Monday 18 May 2020 9:38
by pr0phet
already tried to do with sancla
making install with curl -L
https://install.domoticz.com | bash
i've tried for 2 day at least, with all instructions ive found on this forum
Posted: Monday 18 May 2020 9:56
by sancla
waaren wrote: Monday 18 May 2020 9:32
@Waren
Could this error be related to the Cloudflare security, redirecting the user as part of the Cloudflare DDOS mitigation?
Would it be an idea to use a second domain for installation (or a subdomain)?
@pr0phet
Can you connect to
www.domoticz.com directly or are you getting the Cloudflare page verifyingyou are not a robot with captcha?
Posted: Monday 18 May 2020 9:59
by pr0phet
@sancla connectin' whithout any troubles
Posted: Monday 18 May 2020 10:14
by waaren
sancla wrote: Monday 18 May 2020 9:56
I have no knowledge of the cloudflare mechanisms (and no control over the setup either
This area of domoticz is handled by / -via @gizmocuz
Posted: Monday 18 May 2020 11:17
by pr0phet
tried to change dns & proxy with same result
Posted: Wednesday 20 May 2020 9:27
by pr0phet
problem solved via anonymous proxy located in germany
