Waterpressure from OTGW [solved]
For OpenTherm-gateway related questions in Domoticz
azonneveld
Domoticz version: 2024.4
Post by azonneveld »
I have the intergas hre 28/24 with honeywell round modulation, and the OTGW with espeasy.
Currently I am not able to receive the waterpressure in domoticz.
In the past I controlled the boiler using the homewizard+heatlink and this setup was showing the waterpressure, so the data is present.
I tried the firmware provided in this topic: viewtopic.php?f=26&t=25937
But with that firmware I have no connection at all!
Who can help me out to get the waterpressure?
[edit]
SOLUTION:
OTMonitor is needed, this tool is provided by the OTGW website (free).
1. Disable OTGW hardware in domoticz
2. in the OTMonitor goto >options>connection: connect to the OTGW, using serial or TCP.
3. goto >options>miscellaneous and click: Monitor
4. on the same page, send command: AA=18
5. Now click Gateway.
6. Close OTMonitor, and enable the OTGW in domoticz, the waterpressure is now send to domoticz.
[/edit]
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe (sems&modbus) - open weather map - wol - BBQ detection - rsync backup - zendure
