Cant start domoticz Error: Domoticz(pid:2881, tid:2892('MainWorker')) received fatal signal 6 (Aborted)
Posted: Thursday 14 May 2020 22:55
before two days I tried to control domoticz via Alexicz but no response received by Alexa. Then I checked web server but with no luck.
Here are some logs:
Can anyone please help ?
Here are some logs:
sudo ./domoticz -log /var/log/domoticz.log
2020-05-14 22:35:27.464 Status: Domoticz V2020.2 (c)2012-2020 GizMoCuz
2020-05-14 22:35:27.464 Status: Build Hash: b63341bc0, Date: 2020-04-26 13:47:55
2020-05-14 22:35:27.464 Status: Startup Path: /home/pi/domoticz/
2020-05-14 22:35:27.501 Sunrise: 05:08:00 SunSet: 20:26:00
2020-05-14 22:35:27.501 Day length: 15:18:00 Sun at south: 12:47:00
2020-05-14 22:35:27.501 Civil twilight start: 04:29:00 Civil twilight end: 21:04:00
2020-05-14 22:35:27.501 Nautical twilight start: 03:38:00 Nautical twilight end: 21:55:00
2020-05-14 22:35:27.501 Astronomical twilight start: 02:32:00 Astronomical twilight end: 23:01:00
2020-05-14 22:35:27.590 Status: PluginSystem: Started, Python version '3.7.3'.
2020-05-14 22:35:27.597 Active notification Subsystems: (0/13)
2020-05-14 22:35:27.599 Status: WebServer(HTTP) started on address: :: with port 8080
2020-05-14 22:35:27.604 Status: WebServer(SSL) started on address: :: with port 443
2020-05-14 22:35:27.607 Starting shared server on: :::6144
2020-05-14 22:35:27.607 Status: TCPServer: shared server started...
2020-05-14 22:35:27.607 Status: RxQueue: queue worker started...
2020-05-14 22:35:29.609 Status: Kodi: Started
2020-05-14 22:35:29.609 Status: (Romel LGTV) Started.
2020-05-14 22:35:29.609 Status: YeeLight Worker started...
2020-05-14 22:35:29.609 Status: NotificationSystem: thread started...
2020-05-14 22:35:29.648 Status: EventSystem: reset all events...
2020-05-14 22:35:29.650 Status: EventSystem: reset all device statuses...
terminate called after throwing an instance of 'Json::LogicError'
what(): in Json::Value::resolveReference(key, end): requires objectValue
2020-05-14 22:35:29.703 Error: Domoticz(pid:2881, tid:2892('MainWorker')) received fatal signal 6 (Aborted)
2020-05-14 22:35:29.703 Error: siginfo address=0xb41, address=0xffffffff
2020-05-14 22:35:30.002 Status: PluginSystem: Entering work loop.
2020-05-14 22:35:30.208 Status: (Romel LGTV) Entering work loop.
2020-05-14 22:35:30.208 Status: (Romel LGTV) Initialized version 0.7, author 'Chris Gheen @GameDevHobby'
2020-05-14 22:35:30.212 (Romel LGTV) Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE ALL
2020-05-14 22:35:30.213 (Romel LGTV) Update interval set to 10 (minimum is 10 seconds)
2020-05-14 22:35:30.213 (Romel LGTV) Pushing 'PollIntervalDirective' on to queue
2020-05-14 22:35:30.213 (Romel LGTV) 'HardwareID':'8'
2020-05-14 22:35:30.213 (Romel LGTV) 'HomeFolder':'/home/pi/domoticz/plugins/LGTV/'
2020-05-14 22:35:30.214 (Romel LGTV) 'StartupFolder':'/home/pi/domoticz/'
2020-05-14 22:35:30.214 (Romel LGTV) 'UserDataFolder':'/home/pi/domoticz/'
2020-05-14 22:35:30.214 (Romel LGTV) 'Database':'/home/pi/domoticz/domoticz.db'
2020-05-14 22:35:30.214 (Romel LGTV) 'Language':'en'
2020-05-14 22:35:30.215 (Romel LGTV) 'Version':'0.7'
2020-05-14 22:35:30.215 (Romel LGTV) 'Author':'Chris Gheen @GameDevHobby'
2020-05-14 22:35:30.215 (Romel LGTV) 'Name':'Romel LGTV'
2020-05-14 22:35:30.215 (Romel LGTV) 'Address':'192.168.88.214'
2020-05-14 22:35:30.216 (Romel LGTV) 'Port':'0'
2020-05-14 22:35:30.216 (Romel LGTV) 'Key':'lgtv'
2020-05-14 22:35:30.216 (Romel LGTV) 'Mode1':'20'
2020-05-14 22:35:30.216 (Romel LGTV) 'Mode2':'20:17:42:1E:E9:F6'
2020-05-14 22:35:30.216 (Romel LGTV) 'Mode3':'Volume'
2020-05-14 22:35:30.217 (Romel LGTV) 'Mode5':'10'
2020-05-14 22:35:30.217 (Romel LGTV) 'Mode6':'Debug'
2020-05-14 22:35:30.217 (Romel LGTV) 'DomoticzVersion':'2020.2'
2020-05-14 22:35:30.217 (Romel LGTV) 'DomoticzHash':'b63341bc0'
2020-05-14 22:35:30.218 (Romel LGTV) 'DomoticzBuildTime':'2020-04-26 13:47:55'
2020-05-14 22:35:30.218 (Romel LGTV) Device count: 3
2020-05-14 22:35:30.218 (Romel LGTV) Device: 1 - ID: 22, Name: 'Romel LGTV - Status', nValue: 1, sValue: 'TimeoutError() occurred, is the TV off?
({'returnValue': True, 'channel': {'channelId': '1_22_1_0_61958_519_8395', 'programId': '1_22_1_0_61958_519_8395', 'signalChannelId': '61958_519_8395', 'chanCode': 'UNKNOWN', 'channelMode': 'Terrestrial', 'channelModeId': 0, 'channelType': 'Terrestrial Digital TV', 'channelTypeId': 1, 'channelNumber': '1', 'majorNumber': 1, 'minorNumber': 0, 'channelName': 'NOVA | P', 'skipped': False, 'locked': False, 'descrambled': True, 'scrambled': False, 'serviceType': 16, 'favoriteGroup': [], 'imgUrl': '', 'display': 1, 'satelliteName': ' ', 'fineTuned': False, 'Frequency': 482000, 'shortCut': 0, 'Bandwidth': 0, 'HDTV': False, 'Invisible': False, 'TV': True, 'DTV': True, 'ATV': False, 'Data': False, 'Radio': False, 'Numeric': False, 'PrimaryCh': True, 'specialService': False, 'CASystemIDList': {}, 'CASystemIDListCount': 0, 'groupIdList': [0, 1], 'channelGenreCode': 'UNKNOWN', 'favoriteIdxA': 250, 'favoriteIdxB': 250, 'favoriteIdxC': 250, 'favoriteIdxD': 250, 'imgUrl2': '', 'channelLogoSize': 'UNKNOWN', 'ipChanServerUrl': '', 'payChan': False, 'IPChannelCode': 'UNKNOWN', 'ipCallNumber': 'UNKNOWN', 'otuFlag': False, 'favoriteIdxE': 250, 'favoriteIdxF': 250, 'favoriteIdxG': 250, 'favoriteIdxH': 250, 'satelliteLcn': False, 'waterMarkUrl': 'UNKNOWN', 'channelNameSortKey': '20', 'ipChanType': 'UNKNOWN', 'adultFlag': 0, 'ipChanCategory': 'UNKNOWN', 'ipChanInteractive': False, 'callSign': 'UNKNOWN', 'adFlag': 0, 'configured': False, 'lastUpdated': '', 'ipChanCpId': 'UNKNOWN', 'isFreeviewPlay': 0, 'hasBackward': 0, 'playerService': 'com.webos.service.tv', 'TSID': 61958, 'SVCID': 519}, 'programList': [{'channelId': '1_22_1_0_61958_519_8395', 'duration': 2100, 'endTime': '2020,05,13,17,30,00', 'localEndTime': '2020,05,13,19,30,00', 'localStartTime': '2020,05,13,18,55,00', 'genre': '', 'programId': '8395_61958_519_167', 'programName': 'Comeback', 'rating': [{'ratingString': '', 'ratingValue': 3, 'region': 0, '_id': '276'}], 'signalChannelId': '61958_519_8395', 'startTime': '2020,05,13,16,55,00', 'tableId': 0}, {'channelId': '1_22_1_0_61958_519_8395', 'duration': 3000, 'endTime': '2020,05,13,18,20,00', 'localEndTime': '2020,05,13,20,20,00', 'localStartTime': '2020,05,13,19,30,00', 'genre': '', 'programId': '8395_61958_519_168', 'programName': 'Televizní noviny', 'rating': [{'ratingString': '', 'ratingValue': 3, 'region': 0, '_id': '279'}], 'signalChannelId': '61958_519_8395', 'startTime': '2020,05,13,17,30,00', 'tableId': 0}, {'channelId': '1_22_1_0_61958_519_8395', 'duration': 4200, 'endTime': '2020,05,13,19,30,00', 'localEndTime': '2020,05,13,21,30,00', 'localStartTime': '2020,05,13,20,20,00', 'genre': '', 'programId': '8395_61958_519_169', 'programName': 'MasterChef Česko', 'rating': [{'ratingString': '', 'ratingValue': 3, 'region': 0, '_id': '27c'}], 'signalChannelId': '61958_519_8395', 'startTime': '2020,05,13,18,20,00', 'tableId': 0}, {'channelId': '1_22_1_0_61958_519_8395', 'duration': 3300, 'endTime': '2020,05,13,20,25,00', 'localEndTime': '2020,05,13,22,25,00', 'localStartTime': '2020,05,13,21,30,00', 'genre': '', 'programId': '8395_61958_519_170', 'programName': 'Nova je s vámi', 'rating': [{'ratingString': '', 'ratingValue': 3, 'region': 0, '_id': '27f'}], 'signalChannelId': '61958_519_8395', 'startTime': '2020,05,13,19,30,00', 'tableId': 0}]}
2020-05-14 22:35:30.220 (Romel LGTV) Internal ID: '22'
2020-05-14 22:35:30.220 (Romel LGTV) External ID: '00080001'
2020-05-14 22:35:30.220 (Romel LGTV) Device Name: 'Romel LGTV - Status'
2020-05-14 22:35:30.220 (Romel LGTV) Device nValue: 1
2020-05-14 22:35:30.220 (Romel LGTV) Device sValue: 'TimeoutError() occurred, is the TV off?
2020-05-14 22:35:30.221 (Romel LGTV) Device LastLevel: 0
2020-05-14 22:35:30.221 (Romel LGTV) Device: 2 - ID: 25, Name: 'Romel LGTV - Volume', nValue: 0, sValue: '0'
2020-05-14 22:35:30.222 (Romel LGTV) Internal ID: '25'
2020-05-14 22:35:30.222 (Romel LGTV) External ID: '00080002'
2020-05-14 22:35:30.222 (Romel LGTV) Device Name: 'Romel LGTV - Volume'
2020-05-14 22:35:30.222 (Romel LGTV) Device nValue: 0
2020-05-14 22:35:30.222 (Romel LGTV) Device sValue: '0'
2020-05-14 22:35:30.222 (Romel LGTV) Device LastLevel: -1
2020-05-14 22:35:30.223 (Romel LGTV) Device: 3 - ID: 24, Name: 'Romel LGTV - Source', nValue: 0, sValue: '0'
2020-05-14 22:35:30.223 (Romel LGTV) Internal ID: '24'
2020-05-14 22:35:30.223 (Romel LGTV) External ID: '00080003'
2020-05-14 22:35:30.223 (Romel LGTV) Device Name: 'Romel LGTV - Source'
2020-05-14 22:35:30.223 (Romel LGTV) Device nValue: 0
2020-05-14 22:35:30.223 (Romel LGTV) Device sValue: '0'
2020-05-14 22:35:30.224 (Romel LGTV) Device LastLevel: 0
2020-05-14 22:35:30.224 (Romel LGTV) Notifications are off, add a Notifier Name to enable.
2020-05-14 22:35:30.224 (Romel LGTV) Processing 'PollIntervalDirective' message
2020-05-14 22:35:30.224 (Romel LGTV) Heartbeat interval set to: 10.
2020-05-14 22:35:30.609 Status: MQTT: Connecting to localhost:1883
2020-05-14 22:35:32.851 Error: Thread 12 (Thread 0x701ff220 (LWP 2892)):
2020-05-14 22:35:32.851 Error: #0 __waitpid (options=0, stat_loc=0x701fd208, pid=2900) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2020-05-14 22:35:32.851 Error: #1 __waitpid (pid=2900, stat_loc=0x701fd208, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2020-05-14 22:35:32.851 Error: #2 0x002db8ec in dumpstack_gdb(bool) ()
2020-05-14 22:35:32.851 Error: #3 0x002dbeb8 in signal_handler(int, siginfo_t*, void*) ()
2020-05-14 22:35:32.851 Error: #4 <signal handler called>
2020-05-14 22:35:32.851 Error: #5 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2020-05-14 22:35:32.851 Error: #6 0x76959230 in __GI_abort () at abort.c:79
2020-05-14 22:35:32.851 Error: #7 0x0096d02c in __gnu_cxx::__verbose_terminate_handler() ()
2020-05-14 22:35:32.851 Error: #8 0x008d04cc in __cxxabiv1::__terminate(void (*)()) ()
2020-05-14 22:35:32.851 Error: #9 0x008d0540 in std::terminate() ()
2020-05-14 22:35:32.852 Error: #10 0x008daff0 in __cxa_throw ()
2020-05-14 22:35:32.852 Error: #11 0x006ecaec in Json::throwLogicError(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
2020-05-14 22:35:32.852 Error: #12 0x006f2b98 in Json::Value::resolveReference(char const*, char const*) ()
2020-05-14 22:35:32.852 Error: #13 0x0037bca0 in http::server::CWebServer::GetJSonDevices(Json::Value&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool, bool, bool, long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
2020-05-14 22:35:32.852 Error: #14 0x7c204156 in ?? ()
AbortedCode: Select all
cp 0 0 0.0.0.0:9091 0.0.0.0:* LISTEN 462/transmission-da
tcp 0 0 0.0.0.0:51413 0.0.0.0:* LISTEN 462/transmission-da
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 470/sshd
tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 457/mosquitto
tcp6 0 0 :::51413 :::* LISTEN 462/transmission-da
tcp6 0 0 :::22 :::* LISTEN 470/sshd
tcp6 0 0 :::1883 :::* LISTEN 457/mosquitto
udp 0 0 0.0.0.0:44744 0.0.0.0:* 252/systemd-timesyn
udp 0 0 0.0.0.0:51413 0.0.0.0:* 462/transmission-da
udp 0 0 0.0.0.0:5353 0.0.0.0:* 294/avahi-daemon: r
udp 0 0 0.0.0.0:68 0.0.0.0:* 455/dhcpcd
udp 0 0 0.0.0.0:41031 0.0.0.0:* 294/avahi-daemon: r
udp6 0 0 :::45765 :::* 294/avahi-daemon: r
udp6 0 0 :::5353 :::* 294/avahi-daemon: rCode: Select all
service domoticz status
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated)
Active: active (exited) since Thu 2020-05-14 22:48:12 CEST; 6min ago
Docs: man:systemd-sysv-generator(8)
Process: 458 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
May 14 22:48:19 raspberrypi domoticz[491]: #5 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
May 14 22:48:19 raspberrypi domoticz[491]: #6 0x769ea230 in __GI_abort () at abort.c:79
May 14 22:48:19 raspberrypi domoticz[491]: #7 0x0096d02c in __gnu_cxx::__verbose_terminate_handler() ()
May 14 22:48:19 raspberrypi domoticz[491]: #8 0x008d04cc in __cxxabiv1::__terminate(void (*)()) ()
May 14 22:48:19 raspberrypi domoticz[491]: #9 0x008d0540 in std::terminate() ()
May 14 22:48:19 raspberrypi domoticz[491]: #10 0x008daff0 in __cxa_throw ()
May 14 22:48:19 raspberrypi domoticz[491]: #11 0x006ecaec in Json::throwLogicError(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
May 14 22:48:19 raspberrypi domoticz[491]: #12 0x006f2b98 in Json::Value::resolveReference(char const*, char const*) ()
May 14 22:48:19 raspberrypi domoticz[491]: #13 0x0037bca0 in http::server::CWebServer::GetJSonDevices(Json::Value&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, s
May 14 22:48:19 raspberrypi domoticz[491]: #14 0x7c204156 in ?? ()
