No hardware after having updated RFXcom433E to latest FW.
Posted: Thursday 14 May 2020 10:21
by franzel
@all,
Yesterday I updated my RFXcom433E to the latest version. After the procedure seemed to have been finished successfully, data was written and having pushed choosen the Runmode Domoticz didn't work anymore. After a while and having rebooted via the commandline Domoticz started again but no hardware was found. I guess due to a missing RFXcom device. Pushing hardware didn't respond neither.
Present firmware was 2020.2. Then I placed the SD card with an older version but with equal result.
After having performed all kind of things, due to the annoyance I can't recall what I've done, besides having flshed the RFXcom433E, I still owed a non working system.
I started reading on the internet whether I might have done something wrong, which IMHO wasn't the fact. Out of the blue Domotics seemed to work again properly. The RFXcom433E was working again too but with the FW of Januar hich I flashed the last time.
I just flashed the RFXcom433E with the latest firmware and again 'no hardware' so I urgently need help.
Is there some special procedure that has to be followed to get my system getting to work properly but with the last firmware on my Device?
Thanks in advance.
Frans
Re: No hardware after having updated RFXcom433E to latest FW.
Posted: Thursday 14 May 2020 10:44
by franzel
Update!!!!
After just having switched once to the previous version of Domotics where some devices were triggeren once, two blinds went down, Domotics webserver showed offline. At last I put back the SD card with the latest FW (2020.2) but still no result. Domoticz seemed to be online again but still no hardware. I rebooten several times and suddenly all seemed to be working again properly so for now I'm happy again.
The cause of all this misery will remain misterious. For now this issue is 'solved'.
Posted: Thursday 14 May 2020 11:29
by waaren
franzel wrote: Thursday 14 May 2020 10:44
Are you using "persistent USB ports" ? (described on
this wiki page )
Posted: Thursday 14 May 2020 13:05
by franzel
I did lsusb but no rfxcom was seen.
I know the procedure from the use in Enigma and will certainly try to perform this solution.
Thanks for now.
Frans
Posted: Thursday 14 May 2020 14:58
by franzel
Still no RFXcom433E device seen via lsusb but in Domoticz there is.
pi@raspberrypi:~ $ lsusb
Bus 001 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Posted: Thursday 14 May 2020 15:19
by waaren
franzel wrote: Thursday 14 May 2020 14:58
Look closer....
sudo lsusb -v | grep 'idVendor\|idProduct\|iProduct\|iSerial'
Posted: Thursday 14 May 2020 16:21
by franzel
That gives actually more information.
I’ll change it as soon as possible.
Due to health-issues it’ll have to wait a while. For now most things work like before. The blockly scenario’s I would like to create will have to wait too.
pi@raspberrypi:~ $ sudo lsusb -v | grep 'idVendor\|idProduct\|iProduct\|iSerial'
can't get device qualifier: Resource temporarily unavailable
can't get debug descriptor: Resource temporarily unavailable
idVendor 0x0403 Future Technology Devices International, Ltd
idProduct 0x6001 FT232 Serial (UART) IC
iProduct 2 RFXtrx433
iSerial 3 A1YUXI5T
idVendor 0x0424 Standard Microsystems Corp.
idProduct 0xec00 SMSC9512/9514 Fast Ethernet Adapter
iProduct 0
iSerial 0
idProduct 0x9514 SMC9514 Hub
iProduct 0
iSerial 0
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
iProduct 2 DWC OTG Controller
iSerial 1 3f980000.usb
pi@raspberrypi:~ $
