Page 1 of 2
Dashticz v3.4.6 beta
Posted: Wednesday 13 May 2020 15:07
by Lokonli
I've just released Dashticz v3.4.6 beta.
Biggest change: A huge rewrite of the graph module to make it better maintainable and behave more predictable. Although we already did quite some testing, probably still some bugs will exist, which I would like to find, and solve, before we create a new master release. So your testing is appreciated :)
Enhancements
* Enable graphs for Voltage and Distance devices
* Parameter timeformat to configure time format for 'alarmmeldingen'.
* TV guide (Dutch: tvgids) made clickable
* More options to customize the graph header. See https://dashticz.readthedocs.io/en/beta ... stomheader
Fixes
* Fix for ANWB Traffic Info (new API)
* Fix for recurring calendar events (older than 3 year, without end date)
For the release notes, see:
https://dashticz.readthedocs.io/en/beta ... notes.html
And then a little bit looking forward:
My plan is to release a new master as soon as possible. However, I noticed a few issues with the custom block names for Domoticz devices as used in CONFIG.js, especially when using subdevices. This is something I would like to fix first before creating the new master.
Further, clinkadink is working on a new dial-based way of representing some devices, which can be used for instance for temperature/setpoints and dimmers. It looks very promising already.
So we are making steps in improving the quality while extending the functionality at the same time. So stay tuned, and healthy. More to come soon.
Re: Dashticz v3.4.6 beta
Posted: Wednesday 13 May 2020 16:20
by Jimster
Great work guys!
Posted: Wednesday 13 May 2020 18:13
by dorenberg
good work! Will update now. As I have combined some blocks into 1 block for temp/RH sensors. I also get the dewpoint now. Is there a way to make this optional? I removed the pieces in blocks.js to remove this.
Posted: Wednesday 13 May 2020 22:29
by Lokonli
Try with a custom value string, like this:
blocks[16] = {
  single_block: true,
  value : "<Temp> C | <Humidity> % | <Barometer> hPa"
The names between '<>', like <Temp> are the name of fields as reported by Domoticz as device info.
Posted: Thursday 14 May 2020 0:55
by nfuse
nice will test asap!
Posted: Thursday 14 May 2020 14:20
by dorenberg
Thanks for the option. Do you know whether it is possible to get several sensor info in 1 block. Like for instance, several temperatures in a table? As these are for information only for me, that saves a lot of space.
Posted: Thursday 14 May 2020 15:25
by Jimster
I found some things in the graphs which are not correct.
The totals for the month view are not correct. For example. The month graph says my gas usage for March was 6.61m3. This is not correct. The first week the usage was already more than 7m3. The totals for the week view also doesn't seems correct.
And also the things I mentioned in this topic:
https://www.domoticz.com/forum/viewtopi ... 67&t=31534
For Dutch, the weeks starts on Sunday and should start on Monday.
I noticed the week bar is only updated during the day on the first day of the week. On the other days, the bar remains the same until the day ends, then the usage of that day is added to the bar. I'm not sure if this is intended.
The graph header value is updated realtime, this is nice :)
Posted: Thursday 14 May 2020 17:15
by Lokonli
dorenberg wrote: Thursday 14 May 2020 14:20 Thanks for the option. Do you know whether it is possible to get several sensor info in 1 block. Like for instance, several temperatures in a table? As these are for information only for me, that saves a lot of space.
You can combine several sensors in one graph, by using the groupdByDevice parameter.
See the link for an example:
https://dashticz.readthedocs.io/en/beta ... upbydevice
There is no standard functionality to combine device info in plain text format, but you could use custom.js for this. First define a block for the temperature device (or any other device) that is updated most often:
In CONFIG.js:
blocks['templist'] = {
  idx: 16
Then add to custom.js:
function getBlock_16(block) {
  var html = "";
  html += '<div class="col-xs-4 col-icon">';
  html += iconORimage(block, "fas fa-thermometer-half", "", "icon");
  html += "</div>";
  html += '<div class="col-xs-8 col-data">';
  html += "<table>";
  var devices = Domoticz.getAllDevices();
  var deviceList = [16, 2];
  var nameList = ['binnen', 'buiten'];
  deviceList.forEach(function (idx, i) {
	var temp = devices[idx].Temp;
	console.log(devices[idx]);
    html += "<tr><td>" + nameList[i] + "</td><td>:</td><td>" + temp + "</td></tr>";
  html += "</table>";
  html += "</div>";
  return html;
16, 2 are example Domoticz devices. (Fill in your own device ids)
Posted: Thursday 14 May 2020 19:20
by dorenberg
Good one. Something to try in the weekend. Basic functionality is working so far. Let's see if it is of real added value.
Posted: Thursday 14 May 2020 22:41
by HansieNL
Jimster wrote: Thursday 14 May 2020 15:25 I found some things in the graphs which are not correct.
I see the same incorrect values for the P1 electricity device.
Posted: Friday 15 May 2020 23:38
by Lokonli
Currently the graph groupBy function takes the average of the measurement values for most device types.
I've just added a small change to the latest beta:
In a graph block you can add the parameter 'aggregate' which can have the value 'sum' or 'avg' to define how to compute the aggregation.
blocks['graph_43'] = {
   groupBy: 'week',
   aggregate: 'sum'
Posted: Saturday 16 May 2020 20:12
by Aadr
Dear Lokoni,
after updating to latest beta some serious problems occur.
I lost the 'clock' (digital display), the horizontal swipe doesn't work anymore and the left menu doesn't response anymore.
And i have lost several graphs, but that was to expect, because this update was about graphs.
I revert back to master and the clock, swipe and menu worked fine.
I am on Domoticz version 4.107 on an Raspberry 1 with Jessie.
i hope you can solve the problem.
greetings
Posted: Sunday 17 May 2020 0:04
by Lokonli
Can you post your CONFIG.js and custom.js (if you use that)? Then I'll have a look.
Posted: Sunday 17 May 2020 0:09
by HansieNL
Lokonli wrote: Friday 15 May 2020 23:38 Currently the graph groupBy function takes the average of the measurement values for most device types.
   groupBy: 'week',
   aggregate: 'sum'
I installed latest beta and added aggregate: 'sum' to a custom P1 gas grapgh. Looks like still the average is shown. Should this parameter work with a custom graph too?
blocks['graph_gas_verbruik'] = {
    title: 'Gas',
    devices: [320],
    graphTypes: ['v'],
    graph: ['bar'],
    datasetColors: ['#8D8CC6'],
    beginAtZero: true,
    custom : {
        "per dag": {
            range: 'month',
            groupBy: 'day',
            data: {
                Verbruik: 'd.v_320',
        "per maand": {
            range: 'year',
            groupBy: 'month',
            aggregate: 'sum',
            data: {
    legend: true,
    buttonsSize: 12,
    width: 12,
    // debugButton: true
  "mountPoint": "#block_68",
  "block": {
    "width": 12,
    "datasetColors": [
      "#8D8CC6"
    "barWidth": 0.9,
    "beginAtZero": true,
    "borderDash": [],
    "borderWidth": 2,
    "buttonsBorder": "white",
    "buttonsColor": "black",
    "buttonsFill": "white",
    "buttonsIcon": "#686868",
    "buttonsMarginX": 2,
    "buttonsMarginY": 0,
    "buttonsPadX": 6,
    "buttonsPadY": 2,
    "buttonsRadius": 0,
    "buttonsShadow": false,
    "buttonsSize": 12,
    "buttonsText": false,
    "cartesian": "linear",
    "custom": {
      "per dag": {
        "range": "month",
        "groupBy": "day",
        "data": {
          "Verbruik": "d.v_320"
      "per maand": {
        "range": "year",
        "groupBy": "month",
        "aggregate": "sum",
        "data": {
    "customHeader": false,
    "debugButton": true,
    "displayFormats": false,
    "drawOrderDay": false,
    "drawOrderLast": false,
    "drawOrderMonth": false,
    "flash": false,
    "format": true,
    "gradients": false,
    "graph": [
      "bar"
    "graphTypes": [
      "v"
    "groupBy": false,
    "groupByDevice": false,
    "height": false,
    "iconColour": "grey",
    "interval": 1,
    "legend": true,
    "lineFill": false,
    "lineTension": 0.1,
    "maxTicksLimit": null,
    "method": 1,
    "pointBorderColor": [
      "grey"
    "pointBorderWidth": 0,
    "pointRadius": 0,
    "pointStyle": false,
    "range": "initial",
    "refresh": 300,
    "reverseTime": false,
    "sortDevices": false,
    "spanGaps": false,
    "stacked": false,
    "title": "Gas",
    "tooltiptotal": false,
    "zoom": false,
    "devices": [
      320
    "isPopup": true
  "key": "block_68",
  "name": "graph",
  "graphDevices": [
      "AddjMulti": 1,
      "AddjMulti2": 1,
      "AddjValue": 0,
      "AddjValue2": 0,
      "BatteryLevel": 255,
      "Counter": "2367.521",
      "CounterToday": "0.503 m3",
      "CustomImage": 0,
      "Data": "2367.521",
      "Description": "",
      "Favorite": 0,
      "HardwareID": 12,
      "HardwareName": "P1 Smart Meter",
      "HardwareType": "P1 Smart Meter USB",
      "HardwareTypeVal": 4,
      "HaveTimeout": false,
      "ID": "0001",
      "LastUpdate": "2020-05-17 01:03:50",
      "Name": "Gas",
      "Notifications": "false",
      "PlanID": "0",
      "PlanIDs": [
        0
      "Protected": false,
      "ShowNotifications": true,
      "SignalLevel": "-",
      "SubType": "Gas",
      "SwitchTypeVal": 1,
      "Timers": "false",
      "Type": "P1 Smart Meter",
      "TypeImg": "counter",
      "Unit": 2,
      "Used": 1,
      "XOffset": "0",
      "YOffset": "0",
      "idx": 320,
      "currentValue": "0,50 m3",
      "name": "Gas",
      "sensor": "counter",
      "subtype": "Gas",
      "title": "Gas",
      "txtUnit": "m3",
      "txtUnits": [],
      "type": "P1 Smart Meter"
  "graphIdx": "block_68",
  "lastRefreshTime": 1589670421,
  "range": "year",
  "title": "Gas",
  "params": [
    "type=graph&sensor=counter&idx=320&range=year&method=1"
  "subtype": "Gas",
  "txtUnits": [
    "m3"
  "data": {
    "result": [
        "d": "2019-05-01",
        "v_320": 0.8686666666666665
        "d": "2019-06-01",
        "v_320": 0.5343333333333333
        "d": "2019-07-01",
        "v_320": 0.3467741935483871
        "d": "2019-08-01",
        "v_320": 0.3490322580645162
        "d": "2019-09-01",
        "v_320": 0.41866666666666663
        "d": "2019-10-01",
        "v_320": 0.8741935483870968
        "d": "2019-11-01",
        "v_320": 1.9656666666666665
        "d": "2019-12-01",
        "v_320": 2.352258064516129
        "d": "2020-01-01",
        "v_320": 2.5576666666666665
        "d": "2020-02-01",
        "v_320": 2.6096551724137935
        "d": "2020-03-01",
        "v_320": 2.2787096774193554
        "d": "2020-04-01",
        "v_320": 0.9463333333333335
        "d": "2020-05-01",
        "v_320": 1.139375
    "status": "OK",
    "title": "Graph day",
  "realrange": "year",
  "dataFilterCount": 0,
  "dataFilterUnit": "",
  "groupBy": "month",
  "customRange": true,
  "customRangeName": "per dag",
  "graphConfig": {
    "range": "year",
    "groupBy": "month",
    "aggregate": "sum",
    "data": {
  "keys": [
    "v"
  "ykeys": [
    "Verbruik"
  "txtUnit": "m3",
  "ylabels": [
    "m³"
  "chartctx": "graphoutput_block_68",
  "loadingTooltip": false,
  "aggregate": "sum"
Posted: Sunday 17 May 2020 9:05
by Aadr
Dear Lokonli
i do not use custom.js and i use a raspberry 3B instead of the raspberry 1 i mentioned earlier.
i am not so familiar with writing a post, so i hope that my config is readable.
var config = {}
config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SV
config['user_name'] = 'stripped';
config['pass_word'] = 'stripped';
config['domoticz_ip'] = 'stripped';
config['use_favorites'] = 0; //Request all Domoticz Devices, not only favorites
config['auto_positioning'] = 0; // Use 0 this if you have defined your own columns
config['app_title'] = 'stripped';
config['last_update'] = 1;
config['standard_graph'] = 'day';
config['vertical_scroll'] = 0;
config['enable_swiper'] = 2;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '0';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'coverflow';
config['no_rgb'] = 0;
config['hide_off_button'] = 0;
config['timeformat'] = 'DD-MM-YY HH:mm';
config['news_scroll_after'] = '10'
//////////////////////////////////////////var///////////////////////////////////////////
var calendars = {}
calendars.business = {
maxitems: 8,
url: 'https://calendar.google.com/calendar/',
icalurl: 'stripped' ,
icon: 'far fa-calendar-alt'
//////////////////////////////////////Definition of blocks////////////////////////////////
blocks = {}
blocks['myblocktitle_1'] = {
type: 'blocktitle',
title: 'Schakelaars'
blocks['myblocktitle_2'] = {
type: 'blocktitle',
title: 'Verbruik'
blocks['myblocktitle_3'] = {
type: 'blocktitle',
title: 'Schak'
blocks['myblocktitle_4'] = {
type: 'blocktitle',
title: 'Agenda'
blocks['myblocktitle_5'] = {
type: 'blocktitle',
title: 'Bestuurskamer'
blocks['myblocktitle_6'] = {
type: 'blocktitle',
title: 'Kantine'
blocks['myblocktitle_7'] = {
type: 'blocktitle',
title: 'Kleedkamers'
blocks['myblocktitle_8'] = {
type: 'blocktitle',
title: 'Commissiekamer'
blocks['s1'] = {
title: 'Sfeerverlichting',
width: 12
blocks[227] = { //ventilator ballenhok
icon: 'fas fa-fan',
width: 12
blocks[168] = {
title: 'Biervat',
width: 4
blocks['Graph_Biervat'] = {
width: 12,
devices: [168],
legend: true,
height: '260px'
blocks[158] = { //warmwaterpomp
icon: 'fas fa-shower',
width: 12
blocks[33] = { //straatverlichting
title: 'Straat',
width: 12
blocks[118] = { //contourverlichting
title: 'Contour',
width: 12
blocks[117] = { //tribuneverlichting
title: 'Tribune',
width: 12
blocks[37] = { //veldverlichting A1
title: 'Veldverlichting A1',
width: 12
blocks[36] = { //veldverlichting A2
title: 'Veldverlichting A2',
width: 12
blocks[32] = { //veldverlichting B
title: 'Veldverlichting B',
width: 12
blocks[144] = { //bestuurskamerverlichting
title: 'Bestuurskamer',
width: 12
blocks[177] = { //kassaverlichting
title: 'Kassa',
width: 12
blocks[194] = { //Gekleurde lampen
title: 'Kleurenspots',
width: 12
blocks[220] = { //fotowand
title: 'Fotowand',
width: 12
blocks[188] = { //bestuurskamerverlichting
title: ' Status Bestuurskamer',
protected: true,
width: 6
// Verwarming Kantine
blocks[3] = { //tempratuur kantine2
title: 'Kantine',
width: 4
blocks[234] = { //tempratuur Commissiekamer
title: 'Commissiekamer',
width: 24
blocks[196] = {
title: 'Override',
width: 12
blocks[157] = {
title: 'Status Kantine',
protected: true,
icon: 'fas fa-fire-alt',
width: 12
blocks[195] = {
title: 'Keuze Kantine',
width: 12
blocks[198] = { //kantine
title: 'Gewenste Temp.',
width: 12
// verwarming bestuurskamer
blocks[235] = { //temperatuur bestuurskamer
width: 12
blocks[105] = { //thermostaat Bestuurskamer
title: 'Keuze Bestuurskamer',
width: 12
blocks[106] = { //thermostaat Bestuurskamer
title: 'Bestuurkamer',
width: 12
blocks[108] = { // bestuurskamer
width: 12
blocks[159] = {
title: 'Status Bestuurskamer',
protected: true,
width: 12
// verwarming kleedkamer
blocks[123] = { //thermostaat Kleedkamer
width: 12
blocks[124] = { //thermostaat Kleedkamer
width: 12
blocks[126] = { // Kleedkamerkamer
width: 12
blocks[156] = {
title: 'Status Kleedkamers',
protected: true,
width: 12
// verwarming commissiekamer
blocks[111] = { //thermostaat commissiekamer
width: 12
blocks[112] = { //thermostaat commissiekamer
title: 'Keuze Commissiekamer',
width: 12
blocks[114] = { // commissiekamer
width: 12
blocks[160] = {
title: 'Status Commissiekamer',
protected: true,
width: 12
blocks[247] = { //Agenda Kantine
icon: 'far fa-calendar-alt',
width: 12
blocks[249] = { //Agenda Bestuurskamer
width: 12
blocks[248] = { //Agenda Kleedkamers
width: 12
blocks[250] = { //Agenda Commissiekamer
width: 12
blocks[214] = { //electriciteit
icon: 'fas fa-bolt',
width: 6
blocks[166] = {
title: 'Hal',
last_update: true,
width: 6
blocks[20] = {
title: 'Bestuurskamer Voor',
last_update: true,
width: 6
blocks[187] = {
title: 'Bestuurskamer Achter',
last_update: true,
width: 6
blocks['graph_commissiekamer'] = {
devices: [234],
legend: true,
width: 12,
height: '210px',
legend: {
'te_234' : 'temp',
'hu_234' : 'hum'
blocks['graph_bestuurskamer'] = {
devices: [235],
legend: true,
width: 12,
height: '210px',
legend: {
'te_235' : 'temp',
'hu_235' : 'hum'
blocks['graph_owl'] = {
width: 12,
devices: [214],
height: '260px'
blocks['graph_kantine'] = {
title: 'Kantine',
devices: [3],
legend: true,
width: 12,
height: '210px',
legend: {
'te_3' : 'temp',
'hu_3' : 'hum'
blocks['multigraph_Bierhok'] = {
title: 'Buiten vs Bierhok Temp',
devices: [ 136, 168],
graph: 'line',
buttonsBorder: '#ccc',
buttonsColor: '#ccc',
buttonsFill: 'transparent',
buttonsIcon: 'Blue',
buttonsPadX: 10,
buttonsPadY: 5,
buttonsMarginX: 5,
buttonsMarginY: 2,
buttonsRadius: 0,
buttonsShadow: 'rgba(2, 117, 216, 0.2)',
buttonsSize: 12,
height: '260px',
custom : {
"Last hours": {
range: 'day',
filter: '6 hours',
data: {
te_136: 'd.te_136',
te_168: 'd.te_168',
delta: 'd.te_136-d.te_168'
"Last 2 weeks": {
range: 'month',
filter: '14 days',
data: {
te_136: 'd.te_136',
te_168: 'd.te_168',
"Last 6 months": {
range: 'year',
filter: '6 months',
data: {
te_136: 'd.te_136',
te_168: 'd.te_168',
legend: {
'te_136': 'Bierhok',
'te_168': 'Buiten',
'delta': 'Verschil'
blocks[238] = {
width: 6,
blocks['graph_zon'] = {
graph: 'bar',
width: 12,
devices: [245],
height: '260px'
blocks['graph_verbruik'] = {
width: 12,
devices: [239],
height: '260px'
blocks[221] = {
title: 'Webtv Alb',
icon: 'fab fa-adversal',
width: 12
blocks[229] = {
title: 'Webtv Kin',
width: 12
blocks[14] = {
title: 'Sigaarlamp 1',
width: 12
blocks[175] = {
title: 'Sigaarlamp 2',
width: 12
blocks[174] = {
title: 'Sigaarlamp 3',
width: 12
blocks[13] = {
title: 'Sigaarlamp 4',
width: 12
blocks[193] = {
title: 'Sigaarlamp 5',
width: 12
blocks[206] = {
title: 'Sigaarlamp 6',
width: 12
blocks[8] = {
title: 'Barlampen 1',
width: 12
blocks[190] = {
title: 'Barlampen 2',
width: 12
blocks[205] = {
title: 'Barlampen 3',
width: 12
blocks['gmail_calendars'] = {
type: 'calendar',
layout: 2,
icalurl: {
Personal: {
ics: 'stripped' ,
color: 'white',
Business: {
ics: 'stripped',
color: 'yellow'
holidayurl: 'https://www.officeholidays.com/ics/netherlands',
maxitems: 100,
weeks: 5,
lastweek: true,
isoweek: false,
width: 12
blocks['regio-voetbal'] = {
feed: 'https://www.regio-voetbal.nl/rss/feed',
showimages: true,
blocks['hvelden'] = {
feed: 'https://rss.hollandsevelden.nl/competit ... d-1/za/1c/',
showimages: true,
blocks['cam1'] = {
type: 'camera',
imageUrl: 'stripped',
videoUrl: 'stripped',
refresh: 1000,
width: 12,
height: 300
blocks['cam2'] = {
type: 'camera',
refresh: 1000,
width: 12,
height: 300
////////////////////// FRAMES ///////////////////////////
var frames = {}
frames.weather = {
frameurl:"//forecast.io/embed/#lat=51.887276&lon=4.685896&name=Nieuw Lekkerland&color=#0000ff&font=Helvetica&fontColor=#ffffff&units=si&text-color=#fff&",
height: 210
frames.stand = {
frameurl:"https://embed.hollandsevelden.nl/compet ... =%23f3f3f3",
height: 605,
scrollbars: false
/////////////////////////////////////////////buttons/////////////////
buttons = {}
buttons.logo = {
width: 12,
isimage : true,
image: 'logo.png',
buttons.page1 = {
width: 12,
icon: 'fas fa-home',
slide: 1
buttons.page2 = {
width: 12,
icon: 'fas fa-lightbulb',
slide: 2
buttons.page3 = {
width: 12,
icon: 'fab fa-gripfire',
slide: 3
buttons.page4 = {
width: 12,
slide: 4
buttons.page5 = {
width: 12,
icon: 'fas fa-chart-line',
slide: 5
buttons.page6 = {
width: 12,
icon: 'fas fa-video',
slide: 6
////////////////////////////////Definition of columns//////////////////////////////////
columns = {}
var columns = {}
columns['bar'] = {}
columns['bar']['blocks'] = ['logo']
columns['menu'] = {
blocks: [ buttons.logo, buttons.page1, buttons.page2, buttons.page3, buttons.page4, buttons.page5, buttons.page6],
width: 1
columns[1] = { //startpagina
blocks : ['clock',frames.weather, 'news'],
width: 5,
columns[2] = { //startpagina
blocks : [frames.stand, calendars.business ],
width: 6
columns[3] = { //startpagina
blocks: ['clock',frames.weather, 'news','regio-voetbal' ],
width: 5
columns[4] = { //schakelaars
blocks: ['s1',14,175,174,13,193,206,236,237],
width: 4
columns[5] = { //schakelaars
blocks: [8,190,205,177,194,220,33,117,118],
width: 3
columns[6] = { //schakelaars
blocks: [227,158,37,36,32,144,221,229],
width: 4
columns[7] = { //agenda
blocks: ['gmail_calendars'],
width: 11
columns[8] = {
blocks: ['cam1'],
width: 4
columns[9] = {
blocks: ['cam2'],
width: 4
columns[10] = { //verwarming kantine
blocks: ['myblocktitle_6',247,195,157,198,'graph_kantine','graph_commissiekamer'],
width: 4
columns[11] = { //verwarming kleedkamer
blocks: ['myblocktitle_7',248,123,156,126,'myblocktitle_8',250,111,160,114],
width: 3
columns[12] = { //verwarming bestuurkamer
blocks: ['myblocktitle_5',249,105,159,108,'graph_bestuurskamer','graph_commissiekamer'],
width: 4
columns[13] = { //grafieken
blocks: ['graph_zon','graph_verbruik','multigraph_Bierhok'],
width: 6
columns[14] = { //grafieken
blocks: ['graph_owl',238,214],
width: 5
/////////////////////////////////////Definition of screens/////////////////////////////////////////
var screens = {}
screens['default'] = {}
screens['default']['maxwidth'] = 1920;
screens['default']['maxheight'] = 1080;
screens['default'][1] = {} //startpagina
screens['default'][1]['background'] = 'bg9.jpg';
screens['default'][1]['columns'] = ['menu',3,2]
screens['default'][2] = {} //schakelaars
screens['default'][2]['background'] = 'bg9.jpg';
screens['default'][2]['columns'] = ['menu',4,5,6]
screens['default'][3] = {} //verwarming
screens['default'][3]['background'] = 'bg9.jpg';
screens['default'][3]['columns'] = ['menu',10,11,12]
screens['default'][4] = {} //agenda
screens['default'][4]['background'] = 'bg9.jpg';
screens['default'][4]['columns'] = ['menu',7]
screens['default'][5] = {} //grafieken
screens['default'][5]['background'] = 'bg9.jpg';
screens['default'][5]['columns'] = ['menu',13,14]
screens['default'][6] = {} //camera
screens['default'][6]['background'] = 'bg9.jpg';
screens['default'][6]['columns'] = ['menu',8,9]
//screens['tablet'] = {}
//screens['tablet']['maxwidth'] = 2160;
//screens['tablet']['maxheight'] = 1440;
//screens['tablet'][1] = {}
//screens['tablet'][1]['background'] = 'bg8.jpg';
//screens['tablet'][1]['columns'] = ['menu',3,2]
//screens['tablet'][2] = {}
//screens['tablet'][2]['background'] = 'bg8.jpg';
//screens['tablet'][2]['columns'] = ['menu',4,5,6]
//screens['tablet'][3] = {}
//screens['tablet'][3]['background'] = 'bg8.jpg';
//screens['tablet'][3]['columns'] = ['menu',7,8]
//screens['tablet'][4] = {}
//screens['tablet'][4]['background'] = 'bg8.jpg';
//screens['tablet'][4]['columns'] = ['menu',7]
//screens['tablet'][5] = {}
//screens['tablet'][5]['background'] = 'bg8.jpg';
//screens['tablet'][5]['columns'] = ['menu',3]
//screens['tablet'][6] = {}
//screens['tablet'][6]['background'] = 'bg8.jpg';
//screens['tablet'][6]['columns'] = ['menu',8,9]
greetings
Posted: Sunday 17 May 2020 13:41
by Ashitaka
blocks[16] = {
  single_block: true,
  value : "<Temp> C | <Humidity> %"
blocks["16_3"] = {
 title = 'Barometer';
Here my example:
IDX contains 3 sensors.(Temp, Humidity, Barometer)
Once you use the single_block to true, you can't split information into two blocks.
For example I want Temp and Humidity in a single block and the Barometer in a second one, How can I achieve this?
;o) Thanks for the hardwork !
Posted: Sunday 17 May 2020 17:21
by Lokonli
blocks["16_1"] = {
  value: "<Temp>C | <Humidity>%",
  unit: false
blocks["16_3"] = {
  title: 'barometer'
columns[2] = {
  blocks: [
    '16_1', '16_3'
  width: 6,
Posted: Sunday 17 May 2020 23:12
by Ashitaka
Thanks for the tips !
Posted: Monday 18 May 2020 21:33
by Aadr
Dear Lokonli,
I managed to get my config working again. I removed the graphs and the clock appeared again. The menu and swipe also worked again. I will rebuild the graphs from scratch and see what happens.
thank you for all the good work.
greetings
Aad R
Posted: Sunday 24 May 2020 10:02
by Jimster
Any news about the graph issues? They are also in 3.4.8
