Another action could be, that the heating is switched on. But I want the heating to switch on XX minutes before the bedroomlights are switched on.
I do not want to use a second timer, this is confusing when setting the wake-up alarm.
So, I made a script, which detects the next trigger for a specific timer.
Perhaps this script could also useful for someone else.
1. The script should run as a time based script, this makes it running every minute.
2. The script is intended for timers that occur once a day, repeating on a weekly basis.
local VerwarmingEerder = 15 --Minutes pre-trigger is ahead of 'timername'
local timername = 'WakeUpTimer'
local tNow = os.date("*t");
local TimeInMinutes = tNow.min + tNow.hour * 60;
local triggerfound = 0
weekday = tonumber(os.date("%w")) --zaterdag = 6 --- zondag = 0
if weekday == 0 then
weekday = 7
weekdaybitwise = 2^(weekday-1)
function bitand(a, b)
local result = 0
local bitval = 1
while a > 0 and b > 0 do
if a % 2 == 1 and b % 2 == 1 then -- test the rightmost bits
result = result + bitval -- set the current bit
bitval = bitval * 2 -- shift left
a = math.floor(a/2) -- shift right
b = math.floor(b/2)
return result
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
local a = assert(io.popen('curl "http://<DOMOTICZ-IP:PORT>/json.htm?type=schedules&filter=device"'))
local b = a:read('*all')
a:close()
local c = json:decode(b)
local result_table = c['result']
tc = #result_table
for i = 1, tc do
if triggerfound == 0 then
if result_table[i].DevName==timername then
if result_table[i].Active == 'true' then
if tostring(result_table[i].TimerCmd) == '0' then
if bitand(tonumber(result_table[i].Days),weekdaybitwise) > 0 then
t = result_table[i].Time
h = string.sub(t,1,2)
m = string.sub(t,4,5)
minuteofday = tonumber(h)*60+tonumber(m)
if minuteofday - VerwarmingEerder == TimeInMinutes then
---- Actions taken when pre-timer is triggered (f.i. wake the wife so she can make coffee)
triggerfound = 1 --stop further processing of script
