If multiple devices are "On" then
Posted: Monday 11 May 2020 17:02
by Harmvv
Hi I'm new to Domoticz,
I'm trying to write a script that that wil turn on/off some other devices.
The script is working so far with 1 condition but i would like that the script works with multiple conditions.
The script i have so far is:
devices = {23,9} ,
timer = {'at 08:00-07:00'}
execute = function(dz, item)
if item.state == "On" then
dz.devices(13).switchOn()
dz.devices(11).switchOn()
dz.devices(8).switchOff()
dz.devices(6).switchOff()
dz.devices(7).switchOff()
-- if domoticz.devices(23).state == "On" and domoticz.devices(9).state == "On" then
-- if domoticz.devices("Thuis").state == "On" and domoticz.devices("Telefoon opladen").state == "On" then
The if statement will now run if device 23 is on or device 9 is on, but i would like that the script only runs if both devices are on on at the same time.
Beneath the script are some other statements if tried but those did not work.
Thank you
Re: If multiple devices are "On" then
Posted: Monday 11 May 2020 17:56
by Harmvv
Just found out that the time is not working as well
Posted: Monday 11 May 2020 18:37
by waaren
Harmvv wrote: Monday 11 May 2020 17:56
can you try this ?
return
on =
devices =
23,
9,
timer =
'at 08:00-07:00',
logging =
level = domoticz.LOG_DEBUG,
execute = function(dz, item, info)
if item.isDevice then
dz.log('script is now triggered by device: ' .. item.name, dz.LOG_DEBUG)
elseif item.isTimer then
dz.log('script is now triggered by timer: ' .. info.trigger, dz.LOG_DEBUG)
if dz.devices("Thuis").state == "On" and dz.devices("Telefoon opladen").state == "On" then
Posted: Monday 11 May 2020 18:58
by Harmvv
waaren wrote: Monday 11 May 2020 18:37
can you try this ?
return
on =
devices =
23,
9,
timer =
'at 08:00-07:00',
logging =
Hi thanks for your fast response.
This seems to work, so now when device 23 and 9 are on the other devices will turn on/off. But I only want this to work between 08:00 and 07:00 (Later i will change this to nighttime). But you already helped me a lot, maybe i can figure it out by myself. But if you have an idea i would love to hear it.
Re: If multiple devices are "On" then [Solved]
Posted: Monday 11 May 2020 19:08
by waaren
Harmvv wrote: Monday 11 May 2020 18:58
Syntax to do what you want is like below,
return
on =
devices =
[23] = { 'at 08:00-07:00' },
[9] = { 'at 08:00-07:00' },
logging =
